PNW EXPLR
Local Expert Southeast Washington, USA
Kennewick, WA, USA
Denniston
KJ7LYZ
Hopefully that's your work truck lol. j/k.
Ha, nope! This is my daily driven overland rig. I will be installing a custom fabed recessed battery box. This will allow me to run a group 29 deep cycle house battery. I will power my fridge, and RTT accessories without the fear of killing my engine batteries.
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
I figured you'd have something cool planned for it. I just saw two holes and said, whoa!
Reactions: PNW EXPLR
Buckaroo
Bramley, Rotherham, South Yorkshire Forest, UK
Dave
CB Handle: Buckaroo, UK FM Ch.30
Swore at it this evening when it wouldn't start.
at first I thought the spade connector had rattles loose from the starter solenoid again, crawled under the van to slip it back on only to find that the housing bolt of the starter motor was missing.
No wonder the f@cker wouldn't start!
..tomorrow ....searching in the shed for a replacement bolt and a tube of locktite.
Reactions: JCWages
Lanlubber In Remembrance
Mimbres, NM, USA
covey sr
I'd still keep my cut outs for the next owner although he could use aluminum sheets to cover and pop rivet over the holes unless you sell it to another off roader.
Looks like it will make a tidy installation I would like to see when your finished. I might do something similar to the fiberglass panel in the rear of my LRD2 in an existing compartment that has only access from top, to be able to install my solar charger, amp meter and Inverter in the recess instead of a surface mount.
Mimbres, NM, USA
covey sr
When you get mad at your rig and call it names, it will get even with you by spitting bolts and nut or burn your wires. LOL
Reactions: Buckaroo
Mimbres, NM, USA
covey sr
ain't that the truth?
They are just like dogs, kindness will make them love you so be careful what you say to them, I'm NOT joking. Never kick um in their tires or let dogs pee on them. You would be asking for all kinds of problems.
Reactions: Buckaroo
Buckaroo
Dave
that rig of mine gets all the love and attention ( and all of my hard earned money) constantly.
..and if a dog ever peed on my tyres, it would be limping away holding it's cahoonas.
Mimbres, NM, USA
covey sr
Did you ever see a dog pee on an electrified van ?
Shamu
Alamogordo, New Mexico
Markle
Applied some Noico noise mat to my 2004 TJ’s front floorboards (getting her ready for the next Canyonlands trip). I’ll see...hear...if helps reduce some road noise after my Tom Woods CV driveshaft arrives and R&R the front upper control arm bushings. Southwest Jeep, not a speck of rust discovered after pulling up the carpet.
Mimbres, NM, USA
covey sr
View attachment 117888View attachment 117889
I'm impressed. Did it come in a pre cut package just for jeeps. I've never heard of it before.
Shamu
Markle
It comes in several folded sheets; the box is pretty heavy for its size. I cut/shaped the mat in order to preserve the drainage. If I understand the concept, it is not required to wall-to-wall the surface, just enough to reduce vibration. So, application involved drainage preservation and TLAR.
The Jeep is on jack stands so I could adjust the Novak t-case shift cable (so I could get into 4L reliably) and to measure the length & u-joint type for a CV driveshaft to go along with the completed tummy tuck. So...why not try out some noise reduction while waiting. I got the idea from the Embark With Mark channel on YouTube.
Mimbres, NM, USA
covey sr
I have a Ford Escape I use for daily but mostly travel The road noise is bad from the tires mainly I think. It may be inherent to the 4x4 all wheel drive train but it drives me crazy at speeds below 60 mph. You solution may be what I need to do. Thanks for posting and pictures, it looks like a good idea to me.
