HappyOurOverlanding
Verdi Nevada
KI7RAM
Reactions: David S
JCWages
Grass Valley, CA, USA
Wages
Played around with some chalk. Just a quick test of tire pressure with the P285/70/17 Wildpeaks. General knowledge says that with a tire that has a lot more air capacity than the oem tire (255/65/17) may require less air pressure. So at 36psi-35psi (measured with a good gauge) I chalked the tire tread and drove back and forth on my driveway and then checked where the chalk had rubbed off. The fronts wore more evenly than the rears but still showed evidence of overinflation, particularly the passenger side front. The rears showed even more of the chalk still showing on the edges of the tires and were clearly overinflated. I'll do more testing when I have time but for now I felt ok with dropping the pressure back down to F33/R30 where I had it before the dealer raised it back up to placard levels (35psi).
Front Driver side was fairly close to evenly worn but the edges still showed more chalk. The photo makes the wear look more even than what I see in person.
Front Passenger side
Rear Driver side
Rexplorer
Educator I
4,360
Lake Country, BC, Canada
I've had 7" light bars mounted on my roofrack for a while now. 1 on each side and 1 over the rear door. Today they finally got wired up.
Used the ol' through the roofrack bolt hole trick and a liberal application of silicone.
The wires from the front meet the wires from outside under a conveniently placed random plastic piece.
Room for 1 more wire if i go down a gauge. Maybe future front bar? Ran a second wire all the way back just in case.
AVTA
Westford, MA
No pictures but spent 4 hours trying to find out why the ECM had no communication after installing a switch. Turned out the main CAN BUS wires in the main harness snapped. That's what I get for trying to wire my lights the right way...
HappyOurOverlanding
Verdi Nevada
KI7RAM
Doesn't that reduce the integrity of the rackk? Just thinking out loud here.[emoji848]
Reactions: Magic Mike
Rexplorer
Educator I
4,360
Maybe a bit, but its 1 out of 12 bolts and i barely ever put anything up there. I can and will move it to a roof gromet if it ever causes an issue. Seems many others have rocked this without a prkblem. Some even with rtts.
