I installed a power hub:
I use a lot of electric devices when I'm in camp. Many of these devises are from Goal Zero, GoPro, etc... they all require USB ports to charge. I decided today, to fix one of my frustrations when traveling. I add a USB power hub.
I chose the RAM Tough-HUB
6 qty 5v Powered USB 2.0 Ports
- 1 qty 10/100 MBPS Ethernet Port
- Threaded power input for 12-48 VDC input
- Materials used are Self Extinguishing
- Strain Relief connection points
- Ignition Trigger: The ignition trigger can be wired to the ignition of the vehicle (or other 12V ignition source) to provide a timed power shut off to the connected peripherals after the vehicle has been turned off. When the vehicle ignition is switched to off, the RAM Tough-HubTM continues to provide power to the connected peripherals for a pre set duration of time. This unique RAM feature keeps your connected devices powered for quick vehicle stops, avoiding any possible connectivity issues. The timed shut off can be preset for: 5, 15 and 45 minutes
I'm going to keep a little basket to keep all my devices, as I drive. I will do a review, once I have a couple trips under my belt.
