Sandpoint Steve
US NorthWest Region Local Expert
Supporter
Henniker, New Hampshire, United States
Marchiando
KI7POE
Finished My Dual Battery Tmax Install
Firewall with Grommets
Inner Firewall with 300Amp Breaker
Found a use for this little spot on the 3rd gen 4Runner
Controller Mounted
The system is by Weston. Simple in theory and Automatic.
When in a charging state it waits about 5-10 seconds then links the secondary battery in for charging.
When you start to discharge(Turn the truck off) it waits and then isolates the two batteries.
You can also manually link the system for heavy draw situations(Winching).
And you can check battery voltage. Works best when unlinked. When they are linked they read the same.
Probably not as fancy as the big name systems, but So far I like it. And it was only ~$115. Came with the control box, Solenoid, 6awg wire( I upgraded to 4AWG) and all the connectors.
I am running 2 35AH batteries in parallel in my camp kitchen for a total of 70AH and it ran my Norkol TEC II freezer all night. I have a 300A breaker in the front and another mounted with the batteries. If the 4AWG running under the carpet ever shorts out it should break at the front and rear and not burn my truck to the ground.
The 3rd gen 4Runners are tight under the hood so I put the batteries in the back.
Sandpoint Steve
Supporter
Marchiando
KI7POE
Kelly
Kelly
Herrin
KFØDEX
12 lights, 1 sPod, 100,000 lumins...
If you're anywhere near Auburn, Tyler is the guy for electrical and metal fabrication. DM me if you want his contact info. Special thanks to @Midsierracruiser for the introduction.
Joey83
Sandnes, Norway
Joachim
Sandven
My current car and my previous car together for the last time, the yellow one is getting sent too the highway in the sky on friday, I didn't think I would get this emotional over a car, I guess I was wrong. R.I.P. Pugsley the 306, we had so much fun together while it lasted even though you had alot of problems I still had fun.
View attachment 26075View attachment 26076
Sent from my Samsung S7 using OBTalk app
Reactions: Kelly and [DO]Ron
[DO]Ron
Ron
vAch
Yea sometimes you do get attached.. though with my last few cars i didnt. Thy where pretty much just cars for me..though i did like them.. my cruiser is special to me though :)
Good luck on Friday!
Sent from my SM-G903F using OB Talk mobile app
Corey
Auburn, WA.
Actually this was done on Sunday, but I just got the pics online yesterday.
After a long wet winter, I took Chuck out of the spare room and put him out in the rig ready to serve camping duties before too long.
This is the chuckbox that Pat built for me back in 2010.
One day I may go with a Goose Gear plate system in the cargo area, and have some custom slide out modules built for this stuff, and sitting on top of a bigger cargobox.
Lyon McKeil
Sunnyvale, CA
Lyon
McKeil
AI6F WQZP709 M0GVK (UK Ham Licesne)
CAL FIRE
My radiator keeps going dry. I could never find any leaks and at one point I was starting to believe the Garden Gnomes were drinking my radiator water. Well yesterday I fount the leak! it was a slit in an old heater hose. Today. I got a hose similar to the original, did a few minor modification and installed it. Presto! No leaks!
chrispartida
Los Angeles, CA, USA
Partida
Getting ready for a trip to Los Angeles from Nebraska to pick up my daughter who is graduating college. Hopefully a little exploring on the trip. :)
Let me know if you need any recommendations while you're in town. I'm an LA native.
Reactions: norseman
