What are you using for a fridge/freezer.
Comanche
Goodyear, Arizona
Engel is another brand that has a very good reputation. The Engel has a different type of compressor than the others the Sawafuji Swing Motor. It's said to work at more extreme angles and use less energy.
Reactions: Travis Barker
CDN Offroader
St. Albert, AB, Canada
Adam
Houghtaling
Whynter 65 Qt with Travel case. modified the DC power connector to a twist lock style. My only complaint is i can't actually close the door in the FJ with the fridge like this, has to turn it 90 degrees to fit everything.
1Louder
AZ
K
K1LDR
Indel B 51 and slider. May switch to a Dometic CFX-65DZ Dual Zone but also need to install a new slider.
MarkW
What slides are everyone using? I have a Dometic CF50 and with the new stance of my truck a slide will be more beneficial. My biggest problem is that I am limited in depth to something like 29" if I recall correctly. I am also limited on width if I keep it on the side I want to keep it on but that's not a deal breaker.
1Louder
AZ
K
K1LDR
I think the Dometic and TruckFridge.com slides are the same. Too skinny for an ARB Fridge. At least the TruckFridge for the 51 is if they are in fact the same. So you might check to see who has the. Eat deal. Every once and a while TF has a sale.
Reactions: MarkW
MarkW
Just took a look at TruckFridge.com, had never seen their slide before. Will have to take some measurements but might just work and pretty sure it's the cheapest slide I have seen.
Cavo
Off-Road Ranger II
3,379
Great Falls, VA, USA
Colin
Richard
just ordered
I hope I can get by with what it comes with for now. No extra battery, no monitoring gauge, or new 12v plug, the cover or slider. Thank goodness for Amex points!!!!
