![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/nenthusiast2.png)
2023 INTECH FLYER PURSUE - Adventure Package
Bought new from dealer 5/2023 for $19,000
I have added over $3,000 in upgrades/accessories/solar
This is the later 2023 version which added: LP Heater, Onboard 8 Gallon Water, New-Style Fenders & Rear Roof Extension
Slide out kitchen, 2-burner stove, Dometic fridge, 8 gal. water system with elec pump and quick disconnect, LP furnace with wall thermostat, Bluetooth radio, Air Conditioner, Maxxair Fan w/ remote, OVS 270 awning, Ironman rear awning with add-a-room, rear hitch for bike rack, 3rd Cargo Rack crossrail, 200-watt solar system with upgraded Lithium battery
Garage Kept, only outdoors for 35 days during trips! It performed beautifully! No Leaks!
Prior to 1st use: Applied Locktite to all Air Conditioner mount bolts and fan bolts. Has performed flawlessly.
DEALER INCLUDED:
30A Shore Power Cord with 120v plug adapter
Wheel Chocks
Metal Water Hose with Quick Disconnect and Multi Spray head
25' Drinking-safe, lead-free, water hose
All Dealer Provided Accessory/Operating Manuals included
MODIFICATIONS I added:
OVS Nomadic 270 Awning
Ironman 6.5' Awning & Room Package!
Extra Flyer Roof Rack Crossbar (3rd) for mounting solar panels
12v cigarette-type outlet in cabinet (great for CPAP or other 12v accessory)
12v waterproof dual power socket (cigarette type) on tongue box
Milliard Dual-Sided Premium Tri-Folding Mattress (memory foam)
Fitted Sheet for the Milliard Trifold Mattress (supersoft)
Rapdom Tactical M.O.L.L.E. Panel 24"x32" (inside rear door)
Attachment Kit (30 peice) for Molle Panel
The “Chuck Stop” custom made aluminum rear hitch/rear door security device (protects against rear door opening during towing.
CUSTOM SOLAR SYSTEM
During my test run, I ran the fridge round the clock for days. The lowest the battery got was 70% (at night) and solar charged the battery back up to 100% by noon most days. Bluetooth monitoring via app on phone. Over $1,000 in solar/battery system components.
Ecoflow 2x100W Solar Panels
Victron SmartSolar MPPT 100v 20amp charge controller
WEIZE 12v 100Ah LiFePO Lithium Battery w/BMS
NOCO Group 27 Heavy Duty battery tray
Victron Temperature Sensor (included but not installed)
Victron SmartShunt IP65 500A battery monitor (bluetooth)
Renogy 15A Waterproof in-line Fuse Holder
T Tocas 30A breaker (x2)
DC mini 2 pole 25A breaker
iGreely Solar Panel 10awg cable
House Tuning Clamps x8
Blue Sea 12-circuit accessory Fuse Block
I WILL ALSO INCLUDE:
Tri-Lynx Leveler blocks (10-pack) with case
Hose Water Filters (2) w/flexible hose adapter
RV Water Pressure Regulator
Progressive Industries RV Surge Protector, 30 Amp, portable
Reese TowPower Universal Coupler Lock
Extra Set of Keys for Everything!
KickAss Instant Ensuite Camping Shower Tent awning not yet installed
CAMCO Large Outdoor Patio mat 9’x12’
DEALER INCLUDED:
Wheel Chocks
CUSTOM SOLAR SYSTEM
