Does anyone know of any reliable sites to inquire about a vin number? I’ve tried several sites and they don’t match the vehicle at all.
If its 4 your jeep call 1-800-533-5844 ext 1080 (Lisa) Should be able to tell you,I tried the dealership. Only thing they were able to tell me was the engine size which was different then what the used car salesman told me. Trying to find out if it came from the factory with the tow package. It does have the hitch and wiring set up. Also would like to know what trim level it is.
I talked to the people in the service dept. i’ll Try the parts dept tomorrow. Unfortunately I have to do all this over the phone.About the mid 90's, when I needed to order something, I had to input the VIN to insure the options were correct for the part. I'm surprised the dealer wasn't able to tell you what package it had. Most of my life was spent working at a dealer. In the beginning you had to find the option sheet in the car. If it was destroyed or just missing, sometimes it took a bit of work to figure out the options. With a towing package, it could have different alternator, gearing, battery, coolers as well as a hitch. As you can see, you didn't guess.
Unless its old or real obscure, you should be able to get the info. I am assuming you went into the parts department.
Edit: If the vin shows a different engine than the car salesman says. I would approach with caution.
