I just got done building a full onboard shower system for my '14 JKU. Since I have a 2 drawer galley in the rear cargo area, I could never access the small built-in storage area underneath. So I cut it out and built a 10 gal aluminum tank to drop in the big hole that was left. I mounted a 12v, 3gpm diaphragm pump right in front of that, between the springs. A 10 plate heat exchanger is mounted to the driver's side firewall. The heat exchanger is connected straight to the heat core lines. I tee'd off of the exchanger fresh water input line so I could use it for "cold" water, then ran the hot output line and the cold (ambient tempurature) line up and under the rear hood cowl, then over and out through the passenger side (that spot where the mirror dents when they forget to put the strap back on their door and the wind blows it forward and into the fender.) The two lines then go up the A-piller support on my roof rack and into a mixing valve that is attached to a self-contained shower enclosure that deploys in 20 seconds or less. The shower head is connected to a stainless flex gas line so that it can be strapped back inside the shower enclosure bag when not in use. I only completed it last Saturday, so I haven't been able to use it out in the wild yet.
You can see the build on IG
@Mudbug_JK
[/QUOT
aluminum tank:
Any problems yet with skin reactions from aluminum chloride????? Or did you somehow coat the inside? Does the water taste different? If you’ve replaced the tank already, what did you use? Welded hdpe, prefab plastic, other? Thanks for teaching.
