Universal mounts
Lil Bear
Georgia, USA
Working
Toomuch
I've been looking but haven't found what I think will work yet. Does anyone have suggestions or knowledge of a universal style mounting device to use with a tuff stuff bed rack? I would like to find some type of adjustable wire/metal cables that can be tightened down and locked(sorta like the electronic security things on items at the store). They wrap around 4 sides with cable and then you lock it together some how. They will need to be large and adjustable. But if not something like that then just something. I'm trying to mount my jack, traction boards and maybe a shovel for now. Thanks for any help and input!!
Ontario California
SMR
KO6BI
Are you wanting to mount these items with cables or secure them with cables?
Personally, if your looking to mount these especially the jack, I would mount them to a plate. I have seen mounts for roll cages that that would probably work. Once you have a platform, there are different products to lock or secure.
A quick internet search came up with this Rango. Or this Roll bar clamps
The Rango mount was just something I found. The one I linked is designed for their rack not yours. I've seen items like that sold as a generic mounting solution.
Some of the above clamps would work great for mounting, then bolting either directly to them or mounting a plate without having to weld.
Reactions: Lil Bear
Lil Bear
Georgia, USA
Working
Toomuch
The roll bar clamps may work. I've seen things like the Rango but I have neither the equipment nor skills to weld anything! LOL!! I do wish I did though! The cable mounting idea was just a way I thought would work more so for my traction boards due to them being longer then the rack bars. But thank you very much! I will do some more research on the clamps once I get home!
Ontario California
SMR
KO6BI
Good deal.
Half the fun is seeing what you can adapt. If I can get away with it, I try to have all my accessories bolt in. It makes it easier to change something later.
Reactions: Lil Bear
