Toyota Tacoma Registry
Smatts
Maine
Matt
G
KC1HOI
The SPC say SPC on them so that's a dead giveaway.
Hey Now!
#3533
There aren't any markings on the arms themselves. They certainly look like the right ones though... Do you think I was possibly shipped the wrong ones?
Sent from my Pixel using OB Talk mobile app
Smatts
Maine
Matt
G
KC1HOI
SPC makes the Light Racing upper control arms. You received the correct items.
Thanks theick! I was trying to do my own research and it all seemed to check out, I guess I was just a little confused.
EscoTerrestrial
US East Region Member Rep
Port Washington, NY, USA
Juan
Escobar
Sent from my SAMSUNG-SM-G935A using OB Talk mobile app
Hey woundering how does that do in holding the weight of the rtt. I have a similqr set up but always had doubts of the cap hold all the weight., jw
Sent from my SM-G935V using Tapatalk
Joey D
Holladay, UT
Question for the Tacoma owners here, what size tires do you run? I have a 3" lift and I'm thinking about 285/75/16 tires but I'm unsure how much they will rub off road. I know some cutting and trimming is required for street driving, I just don't know how much is require for off road driving.
I also know Nitto makes a 285/70/16 which is nearly the same size as my 265/75/16, just wider. That's also an option.
Reactions: WillRunner
CO_Justin
Olivehurst, CA
Usually you only rub under full lock in reverse... With that being said, I know that is true for guys with 33"s. They typically also require a cab mount chop.
Reactions: Idaholandho
norcalsurf
Fairfax, CA
Just completed the mojave road yesterday and have done some pretty rough roads and she handles excellent! I have top load (super springs) over my rear leafs and it helps a lot. The ARE overland edition is more ridged than other camper shells and it's a tank! Did lots of doughnuts as well and not tippy at all:)
Reactions: bajatacoguy
norcalsurf
Fairfax, CA
Same size 285s some cutting is necessary and best to chop and box body mounts a bit..
bajatacoguy
Portsmouth NH
Lomastro
I have the super springs also & they help a great deal. Nice truck!
Hey Now!
#3533
Reactions: norcalsurf
