I'm set on Discount tire because they have locations everywhere. I was at 4 different ones in AZ and have one 2 miles from me in Winston Salem. I have their road hazzard warranty $37.50 and used it twice within days of getting the tires.BIgger is not always better, but moving to a 33" tire should not be too big a deal. I would be concerned about flexing especially the rear with a larger tire without a lift based on your picture. If you are heavy already with gear, moving to a heavier tire will cause the torque converter and transmission to work harder. If you have an automatic tranny, you wont need to reprogram for shift points, but will need to to correct your speedo. BFG KO2's are without a doubt my favorite do everything tire. They last forever, run well in snow, slush, mud, gravel, fine dirt/sand and are relatively quiet on the highway. They are available by nearly every retailer everywhere and are at an excellent price point.
Discount has the 285/70/17 (33") at $240 but they can be had cheaper. The 265/70/17 (31.5") which I ran for 55k miles is $208. Both come in a C, D or E sidewall. Slight weight difference between the three but not much.
I also went with E rated because of the strength. 265/70/17 are on the back with 2000 miles. since I got them in April. I need at least a pair of tires. If I keep the same size That's what I will do. Since this is the time to decide I thought I would get opinions.
