It is actually not that bad. Off course it is a bit of noise but it is manageable. I tried to make it as compact as possible to avoid turbulence.How much noise does that extension ladder roof platform make? I can barely stand driving 20 mins with a ladder on my roof. I filled all my extension ladder rungs with the expandable foam to stop the whistle and noise on the highway.
Trexgbg. Where did you run the led bar cabling ? I was thinking of going to Biltema and getting some Deck connectors from the boat section . For easy removal . Same here in Norway.. need to sell the house to buy Landcruiser. 2004 XL7 just aquired and liking your modsAfter this I made a roof rack out of two aluminium ladders and some aluminium plates. The roof bars are made for the standrad GV which means that there are a lot of unused space in front of the bars. Therefore I decided to extend the roofrack a bit to maybe use the space above the drivers seat better.
The design is very sturdy and allows for a lot of cargo. (The last picture is before the lift)View attachment 43331 View attachment 43332 View attachment 43333
Sorry, missed your question!Super cool rig. Do you find it annoying having the fridge/freezer up that high? Maybe I missed it, but it seems like you left a very specific notch out in the drawer system, what is that for? Finally, I always want to find out from folks with anex rooms, how often do you find you actually use the anex vs. it's not worth the effort to setup?
-TJ
Can you tell me which snorkel your using ? Living in Norway and you cant easily find offroad addons here because of the age of the car.. Did you get the lift TÜV registered ?So the snorkel is fitted externally, not yet connected under the fenders.
Sup Trexgbg! Found your post, and like what you’ve done. But here we are 3 years later, what’s the XL7 look like now? Are you still using it?Sorry, missed your question!Super cool rig. Do you find it annoying having the fridge/freezer up that high? Maybe I missed it, but it seems like you left a very specific notch out in the drawer system, what is that for? Finally, I always want to find out from folks with anex rooms, how often do you find you actually use the anex vs. it's not worth the effort to setup?
-TJ
Thank you, I am happy with it so far, will continue to build in springtime, more has to be done.
Yeah, the height can be a bit troublesome for anyone that is shorter than me, but I am 181cm so it is okay, but if I decide to lift it another 10cm it will be a problem.
I have two annex in the drawer section and the one in the left is covered and accessible from the back seat. In that part I have my towing cable and starter cables. In the left I thoght that it would be hard to access it so I opened it up. I was planning to have a plastic box in that area. In retrospect I would most likely have kept it covered as there is always stuff falling down in that space that is difficult to get up.
From what I understand, Trexgbg was last online April 9th 2020, I don't think that user is coming back online anytime soon (says my gut)Sup Trexgbg! Found your post, and like what you’ve done. But here we are 3 years later, what’s the XL7 look like now? Are you still using it?
Inventor I
20111
That is indeed a long time since the last log-in. @Bengt N Since Trexgbg is from Sweden, do you know the member and have any idea what might have happened?From what I understand, Trexgbg was last online April 9th 2020, I don't think that user is coming back online anytime soon (says my gut)
I’m going to look in to itThat is indeed a long time since the last log-in. @Bengt N Since Trexgbg is from Sweden, do you know the member and have any idea what might have happened?From what I understand, Trexgbg was last online April 9th 2020, I don't think that user is coming back online anytime soon (says my gut)
