SOLD
$675 - The Winch is new. Never used. Installed and removed in 2 days. Access to clutch lever and remote socket was restricted on my build after install. Had to go with a different option. Could not return after install.
Description:
The WARN ER EVO 12 Standard Duty Winch with a synthetic rope has an 12, 000 lb. capacity and has an idea weight capacity and line speed for 3/4 and 1-ton pickup trucks and all types of large frame rigs that require longer and heavier pulls. The high-performance Albright contactor delivers maximum reliability and is inside the control pack that can be relocated for low-profile installations. Included is a state-of-the-art, two-in-one remote with wired and wireless options for added ease of use and versatility. This winch features an IP68-rated waterproof construction that keeps the elements out, and a durable, one-piece cast-aluminum tie-plate for extra strength and durability. A powerful series-wound motor and planetary gear train deliver faster line speed under load, with lower amp draw. These winches are designed, engineered, and tested in the USA by WARN engineers and have a limited lifetime for mechanical parts and 7 years on the electrical. With its fast line-speed and lower amp draw, the VR EVO series of winches are the hardest-working standard-duty winches we’ve ever made, with tactical styling that looks great up front and at a price that won’t pull you out of your budget.
Features & details:
Standard duty winch with a synthetic rope and an 12, 000 lb. capacity; Ideal for 3/4 and 1-ton pickup trucks and all types of large frame rigs
Powerful series-wound motor and planetary gear train deliver faster line speed under load, with lower amp draw
High-performance Albright contactor delivers maximum reliability; Control packs can be relocated for low-profile installations
Features IP68-rated waterproof construction, two-in-one remote with wired and wireless options, and one-piece cast-aluminum tie-plate
Designed, engineered, and tested in the USA; Limited lifetime for mechanical parts and 7 years on electrical
Product information 12,000 lbs. , Synthetic Rope
Manufacturer WARN
Brand WARN
Model WARN
Item Weight 70.4 pounds
Product Dimensions 21 x 6.3 x 10.1 inches
Item model number 103255
Manufacturer Part Number 103255
Description:
Features & details:
Manufacturer WARN
Brand WARN
Model WARN
