Local Pickup Only - SF BAY AREA - WALNUT CREEK
Used twice - Life changes have interrupted my overlanding/camping plans.
ARB Twin Motor High Performance Portable 12 Volt Air Compressor Kit - $675
- Ultra compact twin motor air compressor kit
- Dual cylinder design makes this the high flowing portable compressor at 6.16 CFM (no load) and 4.65 CFM (at 29 PSI)
- Integrated aluminum air tank and pressure switch regulates pressure between 135 PSI and 150 PSI
- Mounted in a waterproof carry case constructed from a durable impact resistant polymer
- Convenient compartments for storing air hose and other compressor accessories
- Ducted IP55 sealed brushed DC cooling fan and anodized aluminum motor mounting brackets effectively dissipate heat from the motors, heads and electronics allowing for a 100 percent duty cycle (under room temperature conditions)
- Includes: water proof case, twin compressor, air tank, canvas organizer, 20 feet air hose, inflator and blow gun
