Solar Panel Wattage
El Paso, Texas
Z
Varela
Lanlubber, that sounds like a good plan....just my 2 cents, don't go under 2500watt inverter. I have found some good deals at the truck stops. I bought one 15 years ago and still working without problems.
Lanlubber In Remembrance
Mimbres, NM, USA
covey sr
I already have a new 1100w-2200w max inverter. It is a modified sine which doesn't make me happy but the larger pure sine inverters are bigger bucks than I can handle. I'm thinking of buying a much smaller one to handle items that demand pure sine. The smaller size also carries a smaller price. I had not thought about checking at a truck stop for used inverters, probably because the nearest truck stop is 60 miles away since I don't live near an interstate hwy. I know the truckers are always hocking their equipment when low on cash for the road. The next time I go over to Deming NM, which may be this week end, I will check out the one truck stop they have. Another reason I wasnt too worried about a good inverter is because much of my shop equipment is now 12 or 18v powered equipment. The equipment I have that isn't 12v I believe will run off a modified sine inverter. Thanks for the tip.
P.S. where do you live in El Paso (the area) Looks like lower valley in the pics. I lived in Horizon city before I moved here in 1996.
Lanlubber
007
El Paso, Texas
Z
Varela
Lanlubber
Live out east towards Red Sands...I like that area you currently live at. Don't like El Paso during the summer and it's ok during the winter.
Mimbres, NM, USA
covey sr
I know the area well. I own a half acre lot about a block off Montana very close to the old drag strip on the N. side of Montana. I've been all over the red sand hills with my old 67 Bronco and every dirt road clear out to Hueco Tanks and beyond to Sierra Blanca on all the old ranch roads between.
Yes, the heat can be pretty bad and I can remember in 1994 when the temp was over 100 degrees for 60 days straight.
I lived in Horizon city at that time and before that I lived just off Lee Trevino close to Edgemere.
Mimbres, NM, USA
covey sr
I run 4 x 100 watt panels under my Roof Rack at one time and charge 2 x 100 amps deep cycle batteries in parallel all day long.
View attachment 110078View attachment 110079View attachment 110080View attachment 110081View attachment 110082
Where did you get that plug in on your right rear bumper? What do they call it ? And the led lights for each side is neat too. That looks like a very clean set up. Rigs don't get any neater than yours and I really like the older Toyotas, what year is it ?
007
El Paso, Texas
Z
Varela
Search under Marine usb ports.... The LED lights come in handy when I'm up in the CloudC
Thanks.... 94...Search for Marine USB ports.... The LED light are great for maneuvering in the Forrest at night. Let's me see the trees to all around me when maneuvering.
Mimbres, NM, USA
covey sr
Where did you get the led lights and do you have a number or make for them.
Mimbres, NM, USA
covey sr
I found a video that in my opinion is very neat. It is meant to be for a small solar emergency type set up, except that the methods shown can be for a much larger set up. This just simplifies it somewhat, at least for me it did.
007
El Paso, Texas
Z
Varela
That is a great little setup for on the road camping.
Mimbres, NM, USA
covey sr
Yup, just replace the battery with a 100ah deep cell marine battery and change the solar panel to 100w, and you have a camping rig that will give you all the power you will need for your frig, computer, phones, and other electrical needs.
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
I picked up a 100W Renogy Solar Power Kit. Came with monocrystalline rigid panel, 30AMP PWN Charge Controller, the cables and hardware, which is mounted to my Yakima roof rack, then into my camper shell connected to fuse box, connected to 1000W Wagan Sine Wave inverter and 100AMP Renogy AMG Battery.
Mimbres, NM, USA
covey sr
Show us your set up when you get it in place. Did you use the two pin power connector to penetrate the roof of side of your shell ?
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
I am unable to send a picture to myself at work right now, but basically ran the solar cables from roof, then dropped it down in-between cab rear window and shell gap. Cause I don't know any better, I just drilled two holes from the inside of bed of truck, below the camper shell, and led the two solar cables through there. Then after I got everything connected, I cleaned up the holes, painted them, then silicone them to make them water proof.
Mimbres, NM, USA
covey sr
You might want to run a piece of rubber hose through the holes to keep from chafing and shorting your lines. Rough roads tend to make things move that shouldn't.
Reactions: RoarinRow
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
Thanks I will need to revisit that. Good thought.
Mimbres, NM, USA
covey sr
Check out the video I posted above. There you will see what is called banana jack. That is what I was referring to
in my earlier post. With a banana jack installed you can run the wires from the solar panel to the jack on the exterior. Then inside run wires from the banana jack to the solar charger. That is what will eliminate the possibility of chafing wires going through a drilled hole in your camper or truck bed.
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
Awesome tip, thank you. I will look into this.
