Smittybilt overlander mattress
Mathes
Local Expert Massachusetts, USA
Norton, Massachusetts, USA
Matthew
Robinson
Hey guys, so I'm trying to replace the mattress in my overlander. I bought a memory foam mattress topper but I don't think it's quite dense enough. What have you done/what's your plan to replace it?
TxJeeper75
Steward I
4,392
San Antonio, TX, USA
Heiman
KI5LHN
Is the mattress bad, or are you just wanting to replace it? I put a 2 inch memory foam topper over the original mattress, and it works fine for me. I'm 6'4" 210lbs. I wouldn't go any larger than 2 inch though, because it is a little more effort to close the RTT now.
RoverLander
Yorba Linda, CA
Don
MacGregor
I'm using a 2" eggcrate memory foam topper on mine. Seems to be fine so far. I bought some fitted sheets to keep everything in place.
23ZERO Fitted Sheets
They are slightly bigger than the Smittybilt (sized for Tepui), but the mattress topper adds some bulk, and you can always put sheet straps on the corners.
Corbet
Durango, CO
Corbet
Hoover
I added Exped inflatable mattresses. Getting ready to ditch the original RTT mattress all together and probably just lay down some dense 3/4” foam under the sleeping pads for the area that lacks coverage from the pads and for during setup/tear down. Should also give me more space when folded. Hoping to be able to keep full sized pillows inside when closed.
