RTT that opens over the tailgate?
The Travelin' Taco
Asheville, NC
Victor
Ray
Greetings All,
I am searching for a RTT that can be mounted in a way that the opening/ladder is over the tailgate. I have found a few where people rotate the tent but have to make additional adjustments to do so Vs. just mounting it. Does anyone out there have such a setup? or at least an idea of a good company to look for?
Thanks!
Beeftaco
Rancho Mission Viejo, CA, USA
Danny
T
I know the Yakima tents do this out of the box without any drilling. I had the first generation and it was poor quality but they seem to have addressed the problems in the newest tents. Might be worth looking at.
Reactions: The Travelin' Taco
Ryan Matthes
OB Ambassador
Supporter +
Chapel Hill, NC
Ryan
Matthes
the Tepui tents I have, have pre-drilled mounting holes for the tent mount rails can go in either orientation. Like said above, it's the mounting rail orientation, not the tent itself. I would be surprised if the other mfgs don't do the same as Tepui with the either direction mounting.
Beeftaco
Danny
T
Just make sure to check the site before you purchase one. I just recently got the Tepui Ayer 2 and was very surprised to find out that the it doesn't support folding off the rear. My guess is has to do with the size since it's their smallest one. It did make my tent orientation decision a lot easier.
alexdnick
Washington, USA
A
N
I have that one, you could make it open out the back, you’d just need different mounting brackets or you could take the mattress off and drill some holes in the proper rear orientation
MarkD
Oirschot, Netherlands
Mark
Dolton
One thing to consider with some tents and mine included is if you change the orientation of the support bars you may well need to cut them down, in my case I had enough adjustment on the front runner rack mounts to keep the supports in the same place
chuckoverland
Traveler II
2,902
Spokane, WA
Yakima used velcro on the two straps that hold the tent closed tight while you put the cover on. The velcro is all stripped up after a year and wont hold. We jerry rigged it with luggage straps. Also the tent itself likes to pop out of the tracks that hold it to the base. Its a quick fix but its annoying.
We have also bought two racks from them and both came with either defective or missing parts.
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
I am only considering the Yakima because I am already invested in their rack system, core locks, basket, etc. Plus I like the way their tent mounts onto the crossbars, which is a configuration I am already used to with their Yakima awning, which I already have lol.
Beeftaco
Danny
T
I would definitely recommend looking at the HD tents if you're looking at yakima. I had the regular tent and the nylon was super thin. I ended up ripping it super easily. The new HD ones have way thicker tents.
I did love the clamp system though. I could pop it off and get it in the garage in about 5 minutes without help.
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
Thanks for the recommendation I will def research more as I’d like to get a RTT this Summer.
