RTT quick disconnects?
NorthRightADV
Kinderhook, Columbia County, New York, United States
Jerome
Hoffert
Do any of you know if the front runner roof top tent quick disconnects can work on a tube style rack like Gobi ? Or is some one making ones that will? I’ll fab something up if that’s my only option. Just wanted to check first. I just installed my 23zero yesterday and it is not going to be fun to take it on and off. Not much room to get my hands to the mounting brackets. Any help would be appreciated. Thanks.
Tim
Oxford, UK
Tim
Lunn
From what I’ve seen the Front Runner brackets are designed to work with their flat bar mounting system (t-slots and M8 bolts) but I guess it would be possible to fab something to clamp to the round bar. I did something similar to mount maxtrax on an ARB rack.
Here’s a link to the install for the quick disconnects in case that helps https://dy55nndrxke1w.cloudfront.net/file/18/lSJerzslrs4JrnlSIZVlSIHxlWuUlS_vZ6S/rev=1/F_TBMK012.pdf
I used a flat plate and some u shaped clamps for the maxtrax mounts.
Unkle Luk
Canton, MS
Lucas
Simmons
I was thinking about doing the same thing, utilizing some 80/20 Extrusions or something similar mounted on the under side of my tube roof rack. Does anyone have the overall height of the assembled bracket( from the mounting surface of the bottom bracket to the bottom of the tent rails)?
Shokgoblr
PA, USA
Shok
Goblr
Ihave1
If its a quick disconnect for you, it is also a quick disconnect for a thief.
Food for thought.
Unkle Luk
Canton, MS
Lucas
Simmons
Food for thought.
Definitely a fair and valid point, and something everyone should consider before using them. For me, after installing them, the tent will be either hanging in my garage or in use, so I am not too worried about it.
Tim
Oxford, UK
Tim
Lunn
The quick release mounts come with padlock fittings. I guess you really only need a padlock on one or two of them though.
