Recommendations on traction board mounts
Jaybadd
Michigan, USA
Jase
Baders
@Offroadnutz, here are some pics of my traction board mounts. The uni-strut is low profile from Home Depot painted black, I mounted it to the cross bars with T-nuts as the bars had T track that made it easy. for round bars, Uni-strut makes all different kinds of clamps, should be able to find a conduit clamp that is close to the same size as your bars, then you can slide them back and forth to fit bar spacing. for the board mounting pins, I use some from Max Trax as I use their boards and they allow me to secure either two or four boards, we typically have two on the WJ and two on the JK, but will move a set over if we are going on a difficult trail or in snow or sand. plus they are lockable. could also use carriage bolts up through the slots secured with slots, and then use wing nuts and washers to secure the boards. as a bonus drill a small hole through the end of the bolt for a mini padlock to prevent the wing nut from being removed.
Thank you so much for the reply. I think this will work perfectly for me. Another quick question. Where did you purchase your T bolts? The ones from the rack manufacturer are $7 a piece and the ones I see on amazon have a lot of negative reviews about rust and shearing. Any recommendations?
MidOH
Mid Ohio
Clark
YourHighness
I just used two plates of flat aluminum, to clamp the bars. Yeah, they spun a bit. But I connected them with another bar, that connects each bar.
Then the boards bolted to that bar. Didn't need to line them up with the cross bars.
Sold. I use truck claws now, instead.
ThundahBeagle
Massachusetts
Andrew
Beagle
Lot of engineers here overthinking this. I highly doubt a half inch hole in the traction board will affect its structural integrity. And done
