Rack lift system like this?
rblumenthal
Suffolk, NY, USA
Russell
Blu
WRUF742
Is anyone aware of a rack lift system similar to what is on the xventure xv-2? I am trying to plan out a trailer but looking into other options besides having tubes slide into another tube. This video shows the system I am referring to:
Thanks
Ontario California
SMR
KO6BI
The system in the video is using tube inside tube (nesting) with support struts.
Building that system is simple except for calculating the support strength.
I use that type of gas support in projects. I end up buying a few sets before I get it right. Fortunately their not too expensive.
If their too weak, it will not support the weight while your installing the lock pin. Too much and its tough to pull them back down.
Once its built, you cant add or subtract too much weight without going to a diffrent pressure support.
Reactions: rblumenthal
rblumenthal
Suffolk, NY, USA
Russell
Blu
WRUF742
great thanks. didnt realize it was that 'simple'. I guess I can do something like this and use an angle piece to attach to the trailer box.
Reactions: smritte
Ontario California
SMR
KO6BI
I would not do the tubing the way they did it in the video. They have the outer tube on the bottom. You need to put the inner on the bottom. This way the outside tube will keep the dust from "filling up' the gap. Like an umbrella
I've been towing off road trailers for most of my life. The shear amount of dust on them is incredible. If I had a system built the way the video is, I would have to tear it down all the time and pour the dirt out of the tubes.
rblumenthal
Suffolk, NY, USA
Russell
Blu
WRUF742
That was my concern as well when originally looking at this type of configuration. Besides the dust/debris, having the 'smaller' tube on the inside isnt an issue when it comes to weight right? This is all new to me, but I have a CVT Denali which is heavy, plus awning, etc. Appreciate the info though, def helpful
Ontario California
SMR
KO6BI
Wont matter, weight is weight as long as everything is sized properly.
