Quick Update: Next App Release in Development
Rank IX
Benefactor
15,584
Murguia
KM6YSL
It's been a while since an update and I want to provide some information.
The 3D Map feature is HUGE!!!
It requires a major map migration to support the tech, and with this comes a TON of regression testing to make sure everything is still working as it should. Along with the 3D map, which is the long pole (this means release waits on this feature to be complete), we are doing a ton of small improvements and and feature updates.
In addition to the features, bugs, and improvements listed below - we are also working on high fidelity Gaia import that will support waypoints and GPX tracks.
I will be posting some videos of features in development - we are hoping to release the next version in the next couple weeks (or so).
In development for next release (subset):
DescriptionTypeStatus
Upgrade MapboxFeatureIN PROGRESS
3D Map - Enabled as "Standard" view for all map use, with switch.FeatureIN PROGRESS
Route Planner: Displaying Elevation ProfileFeatureACCEPTED
Category Tabs on My Locations ScreenFeatureACCEPTED
Add a waypoint note field for route planning.FeatureACCEPTED
Track Download and Share Button label ChangesImprovementDELIVERED
Switch to no tracking mode if map is panned.ImprovementBACKLOG
Show total route length in route summary cardsImprovementBACKLOG
Show my location when route planningImprovementBLOCKED
Read/Understand Pasted GPS coordinates in DMS (degrees, minutes, seconds)ImprovementREJECTED
Properly display Member banner colors in the app.ImprovementACCEPTED
Private Locations should not go to approval queue.ImprovementDELIVERED
Preparing for adventure spinnerImprovementACCEPTED
Pop-up Toast with map Mode ChangeImprovementDELIVERED
Permission for 3D MapImprovementACCEPTED
Permission and ability to Delete any location.ImprovementDELIVERED
Map Download: Add Download Instructional ToastImprovementBACKLOG
Increase amount of time locations stay in "recent" searchesImprovementACCEPTED
improve trail recording 'record' / 'pause' UIImprovementACCEPTED
Implement 3D Map permissionImprovementDELIVERED
Have USFS 2016 layer default to OffImprovementACCEPTED
Download Maps - Place first rectangle with handles automaticallyImprovementIN PROGRESS
Default Track Record Names to Date and TimeImprovementACCEPTED
Change Name of 2016 USFS MVUM Roads/Trails layerImprovementACCEPTED
Change “Save” terminology to “Bookmark” for clarity.ImprovementACCEPTED
Add Recent and standard colors to route color picker.ImprovementACCEPTED
Add new Custom Rally Points UI in appImprovementDELIVERED
Add a 3D switch in map settingsImprovementDELIVERED
[Timebox] Tap Route line to insert a waypoint.ImprovementACCEPTED
While editing a Shared route long-pressing waypoint does not provide haptic tap.BugACCEPTED
When selecting a search result from the list of map search results, no zoom in.BugDELIVERED
Waypoint Note Improvements / bugsBugDELIVERED
Unclear messaging resulted in logging off while off-line.BugBACKLOG
Total distance says 0.00 when editing route.BugBACKLOG
TIMEBOX - Can't start a routeBugACCEPTED
Temp pin offline took 2 minutes to fetch summary cardBugBACKLOG
Tapping a search result centers on my location, not POI location:BugDELIVERED
Route Waypoint dots no longer changing color with route color changeBugBLOCKED
Route saved offline (dev) disappeared from app.BugBACKLOG
Reported on android GPX recording timer pauses when app is back groundedBugDELIVERED
Real-time map header updates stopBugIN PROGRESS
Rally Point Map centers on 0,0 instead of my locationBugIN PROGRESS
Quick saving a temp pin as a camp site did not display icon on map.BugBACKLOG
Permissions request during new user flow does not provide details.BugACCEPTED
My Locations back button does not functionBugDELIVERED
Mile markers not spaced 1 mile apartBugACCEPTED
Map search results returned off centerBugDELIVERED
Map Layer settings not being remembered.BugACCEPTED
Map jittering in 3D navigation follow modeBugBACKLOG
Map does not center on locations correctlyBugDELIVERED
Map displaying in perspective view by default.BugDELIVERED
Lose ability to edit previous waypoints on initial creation.BugACCEPTED
Highlight states are not working in the edit resources map search screen.BugACCEPTED
GPX routes not displaying on map unless you tap POI icon.BugACCEPTED
Gpx icon in pending upload does not properly center when trapped in map.BugACCEPTED
Forever spinner editing gpx off-road trailhead.BugBACKLOG
Following a share URL does not Open location until user goes to the map.BugDELIVERED
Followers list is emptyBugDELIVERED
Follow mode does not workBugDELIVERED
Follow filter in forums not displayingBugACCEPTED
Dev - Record button: Fix Dark ModeBugACCEPTED
Deleting any waypoint while route planning will crash the app.BugACCEPTED
Color Picker Cancel and Change button does not show in landscape modeBugACCEPTED
Center on recorded track at zoom extents after savingBugDELIVERED
App crashing frequently when backgrounded.BugBACKLOG
App assuming no permission offline.BugBACKLOG
Android: Route Planning CrashBugDELIVERED
Android does not recognize ob1 as an application to open gpxBugIN REVIEW
3D not showing on AndroidBugDELIVERED
El-Dracho
Ambassador, Europe
Supporter
Off-Road Ranger III
13,288
Lampertheim, Germany
Bjoern
Eldracher
DO3BE
Wow, this is again a massive further development. Fantastic!
Reactions: Michael
