I have seen a lot of these diy builds on you tube but none seem to address the question of can you use it for drinking water. Anybody know the answer or have any experience with a build you can use for drinking water? Thanks!
Influencer III
19540
You are correct about the "Work" type air compressors using oil and that could get into the water, however it is a very small amount. But, nearly all of the small portable air compressors are "Oil-less" they use a rubber diaphragm or other method to pump the air. I have a few small air compressors and none of them use oil, they are all oil-less.PVC pipe can be used in potable water systems. If you build your own container, be sure you clean it out and sanitize it before the first use.
A 100 to 200 ppm bleach solution is an effective sanitizer. Make sure you get at least 30 seconds of contact with all surfaces.
Be sure you rinse the bleach water out before you fill it with drinking water.
Sanitize the system between refills.
Here is where I see a real issue:
Pressurizing the tank. If you pressurize the tank with an air compressor you will introduce oil to the system. Normal "work use" air compressors all blow a little oil and condensation along with the charged air.
Your clean potable water gets contaminated by the compressed air.
Sorry if that seems obsessive, but food/water safety is part of my job.
You could build the tank out of PVC and plumb the water through a suitable water pump, but I don't think that is what you were asking.
.Red trace hose, it’s been used it in the marine industry for years. Home Depot, Ace, Lowe’s.
World Traveler I
