Hello Everyone,
This thread is going to highlight my overland trailer build based off the Dinoot Trailer.
These plans are based off the supplied dinoot frame plans, if i remember correctly this is 6" longer than a standard dinoot (more on why later) They're a little charred from the welding.. oops
I chose to build the frame out of 2" .120wall square tube
The spring brackets are from dinoot, they're pre-welded with minor assembly. I also picked up some axle tube spring mounts.
Im using a $90 harbor freight mig welder for this, didn't feel like driving 30 mins to my dads house every few days to build this thing with the good welders, Pardon the slag
I decided to purchase some of these Zip tie tabs from my friends at motobilt.com, they will come in handy with the trailer wiring & charging system later on
Close up
Here's the trailer sitting on wheels. I'm using a 2200lb axle. 71" hub face with 2" wide wheel spacers to convert over to JK wheel bolt pattern. Eventually i'd like to get a 3500lb axle with an 8x6.5 pattern so i can run the same wheel & tire combo as my jeep LJ (40" tires)
Picture of some misc. tabs i had cut for me by the guys at motobilt, the square and rectangle are for the trailer deck & rear stabilizer jacks. The large tie down handle will be used for holding the spare down & maybe some future storage options.
Heres a picture with everything mostly welded up, im really sorry this photo is blurry. I didn't notice it after i took the picture.
It shows off the 1/4" tongue plate i had CNC plasma cut by a friend.
I guess this would be a good point to show off my rear bumper situation, I run motobilt front & rear bumpers on my jeep. So naturally the curtains need to match the drapes. Also is a picture of an optima battery box made by motobilt. For $35 you cant go wrong!
This should wrap up the frame design, next post will have the decking, tongue box and hitch choices
Close up
