I have a ton of questions. We are planning our trip now. We plan to leave May 20th. I was not able to access your article. Would it be possible for us to communicate via email?
If so,
CraigTreanor@bellsouth.net
A big, big safety concern, travel at night is to be avoided, unless you have aux lighting, and then cautionary. This is because of animals on the road. If doing the trip during the winter months, or early spring, carry extra fuel. Many places are seasonal, and you can't rely on places being open. Also reduced hours come into play! My company suggested, err...almost mandated, that we keep the tank full, by topping off at every opportunity. Plan your fuel stops and expected mileage. Be conservative in your planning, and get some input from locals in the more remote areas. They will know the road conditions.
On a side-note: Sirus XM stops working as you get further North, due to satellite shadow, and positioning. The last 30 miles to Juneau Alaska, thru the hills (from Canada) demonstrated that-very well.
Being May, you should be okay, but check. Hopefully some on here can chime in with better advise than i have. My partner and I did it in December. At the time, Wolves had killed some dogs only 12 miles from Deadhorse, so if camping in tents or with pets, keep that in mind. Having a firearm means travel thru Canada, and permits and restrictions apply. Do not try to bypass that, as customs can be hit or miss, and if they find one, they won't care that you came from the lower 48, and are going to Alaska.
