OB1 app "Bug" reports ONLY
El-Dracho
Ambassador, Europe
Supporter
Protector III
14,131
Lampertheim, Germany
Bjoern
Eldracher
DO3BE
I noticed a little something today. Namely, if we have two members who have the same address, this naturally results in the same position on the member map. So I see only one of the members on the map. This can certainly be solved, right?
Thank you,
Bjoern
El-Dracho
Ambassador, Europe
Supporter
Protector III
14,131
Bjoern
Eldracher
DO3BE
I noticed something else, namely that the feed with the latest posts in the app does not update. There are always the same older posts. I am on version 11.0.3.1021 on Android. What am I doing wrong or does anyone else have this problem?
Thanks a lot!
K12
Trail Blazer III
6,000
Canyon County, Idaho, United States
Beau
K12
Air Force
Thanks a lot!
i found that if i log out and log back into the app it will fix this for a day or two.
Reactions: El-Dracho
D
Deleted member 14476
Guest
Thanks a lot!
I’ve been having this issue also, feed wouldnt update after 20 hours until I reinstalled.
Rank IX
Benefactor
15,584
Murguia
KM6YSL
Thank you for reporting. Is this in the latest version 11.3.0? I am going to have the devs look into this. That info will be helpful. Thank you Connor!
You can look here:
K12
Trail Blazer III
6,000
Beau
K12
Air Force
Testing attachment from Android:
That worked - OK so only some android devices. K12 - can you check permissions for photos? Still, you should have received some warning if permission was not granted.
all permissions are allowed. It allows me to select pictures/videos. but after selection it just will not attach them to the post.
Edit: if I take a picture with my camera in the app it works properly. only problem is selection from gallery.
Rank IX
Benefactor
15,584
Murguia
KM6YSL
Thank you,
Bjoern
Can you give me a member name Bjoern? I'll take a look in the app and see what you see. I want to be sure it is "as designed".
D
Guest
You can look here:
On my app it says 11.2.2 but that’s the latest version I see in the App Store also so I cant update it.
Reactions: Michael
Rank IX
Benefactor
15,584
Murguia
KM6YSL
I believe you found s "real" issue, and it should be resolved. The reason you should be seen even if you are at the same location, is that our map "scatters" people on the map - so we don't reveal actual location. You not showing is not possible as designed. I found that the recent changes to Expedition and Adventure tier hierarchy broke map display, and anyone in the Expedition group was not being displayed. I believe if you search for yourself on the map now, you will see your pin.
I found ANOTHER issue where clicking on your name will bring you to the last tab you were on, so if you are on the Plan tab, you wont see the member! Fixing that too. Thank you!
