SOLD Nor Cal 2000 TJ with Trailer and tent
Ovrwatch
Placerville
Bryan
Schneider
Jeep Wrangler TJ - $19,000
JEEP:
2000 Wrangler TJ Sport
4.0L inline 6 – 150 lbs of compression in all 6 cylinders
100,000 miles
5 speed manual transmission
AC
Alpine MP3 stereo with blue tooth
Roll bar sound bar
Removable hardtop and doors
UPGRADES & MODIFICATIONS:
Full interior roll cage
Rubicon Express 5.5" extreme duty long arm lift kit with bump stops to keep tires from rubbing
TeraFlex 4.1 transfer case with 2-wheel drive low kit
4.88 gears – speedometer is accurate
ARB lockers front and rear
Dana 30 front with warn manual hub kit and chromalloy axles
· Currie heavy-duty steering linkage
· Kilby antirock sway bar
. 5x5.5 bolt pattern conversion kit.
· Large brakes with ceramic front pads and matching rotors
· Stainless steel braided brake lines
· 35" Wrangler MTR on aluminum 15” aluminum wheels
Steel Oil Pan/Transmission Skid Plate
· Heavy duty diff cover / armor
Dana-44 rear with warn full float axle kit and chromalloy axles
· ARB locker
· Drive flanges
· High Angle long travel driveline
· Stainless steel braded brake lines
Full under body skid protection
· Steering box
· Differentials
· Oil Pan
· Transmission / transfer case with “tummy tuck” skid plate
· Rock sliders
Ramsey 9000lb Winch
2 - onboard quick air compressors
Optima yellow top battery
CB radio with secondary speaker
Rock lights
Hansen Rubicon Express front bumper
Custom Rubicon Express rear bumper with tire carrier jerry can and hi-lift jack mounts
Custom built steps that are removable when on the trail
Bikini top with soft doors
Rear dust cover for trunk area
Doors surrounds for hard doors when bikini top is on
1.25 inch body lift
1.25 inch motor mount lift to realign motor and transmission
RECENT MAINTENANCE:
Flow cooler high flow water pump
Thermostat
Fan clutch
All radiator hoses
Front main seal
Pan gasket
Injectors
Front ball joints upgraded heavy duty (Moog)
Front steering U-joints (Moog)
Rear driveline U-joints
Bearings checked and repacked on all 4 axles
This is a non-smoking rig and it is completely set up, turn key and ready to roll. There are no oil leaks and no problematic issues whatsoever. I have two kids who want to go with me now and I need a bigger set up.
Jeephunter
Windsor, CO, USA
Joshua
Brown
JEEP:
100,000 miles
AC
Roll bar sound bar
· ARB locker
· Drive flanges
· Steering box
· Differentials
· Oil Pan
· Rock sliders
Ramsey 9000lb Winch
Rock lights
1.25 inch body lift
RECENT MAINTENANCE:
Thermostat
Fan clutch
All radiator hoses
Front main seal
Pan gasket
Injectors
Got photos???
