- First Name
- Michael
- Last Name
- Denniston
- Member #
3030
- Ham/GMRS Callsign
- KJ7LYZ
Got a Baofeng bf-f8hp strung up to the UT-72.what radio are you running?
I get "lacking airtime"! I have yet to make a contact dispute numerous attempts. I am ready to pull the pin on a ftm-400 but have realized shipping is out 4+weeks.I’m looking into a little hand held... was going to skip it... but it might fit my needs better than a dual band mobile rig... I’m thinking I need a better “Base Station” rig than my FT-2900... it’s a great radio and I’m loving the heck out of it, but feel I’m seriously lacking air time.
Absolutely!!! more than enough ground plane for any mobile antenna. This is what I have on my Jeep. It works fantastic. Diamond Antenna Dual-Band Mobile Antennas SG7900AI have decided the 400 will be purchased.
Can you recommend an antenna? I have a large solid steel front bumper. I would like to hard mount (drill into) the flat surface on the bumper on the driverside. Then I can run a long antenna when I need it. Would this provide the required ground plane?
Ship from HRO to your home in Kennewick... then have wife send it to you...I get "lacking airtime"! I have yet to make a contact dispute numerous attempts. I am ready to pull the pin on a ftm-400 but have realized shipping is out 4+weeks.
Hi all, I've seen this mentioned before but not with any specifics. Does anyone have any detail about what actual usability is lacking in the ftm400 aprs compared with the tmd710ga?The Kenwood TM-d710ga is another good option if APRS is something you want. It is only about $40 more than the 400 and from what I understand does APRS a bit better than the Yaesu FTM-400
I love my 400. Been very happy with its performance.I get "lacking airtime"! I have yet to make a contact dispute numerous attempts. I am ready to pull the pin on a ftm-400 but have realized shipping is out 4+weeks.I’m looking into a little hand held... was going to skip it... but it might fit my needs better than a dual band mobile rig... I’m thinking I need a better “Base Station” rig than my FT-2900... it’s a great radio and I’m loving the heck out of it, but feel I’m seriously lacking air time.
The 400 works great. Very user friendly and feature rich. I would do it again given the choice.Hi all, I've seen this mentioned before but not with any specifics. Does anyone have any detail about what actual usability is lacking in the ftm400 aprs compared with the tmd710ga?The Kenwood TM-d710ga is another good option if APRS is something you want. It is only about $40 more than the 400 and from what I understand does APRS a bit better than the Yaesu FTM-400
As far as using just the radio for APRS, they are about the same but the ftm-400 does do messaging a bit easier by having an on screen keyboard.Hi all, I've seen this mentioned before but not with any specifics. Does anyone have any detail about what actual usability is lacking in the ftm400 aprs compared with the tmd710ga?
So with these two radios the question isn't one of quality it is one of feature set. So both have built-in GPS and both do APRS and both are dual band 2m/70cm. The question you have to asked yourself is regarding APRS and C4FM. If digital voice is important to you then the 400XDR is the radio you want. But if packet/APRS is more important then the D710 is your go to. The 400XDR is capable of C4FM operation where as the D710 isn't. What the D710 has that the 400XDR doesn't is a hardware TNC that you can directly access. Thus allowing for a more robust and capable APRS system. For me I am more concerned with APRS thus I run a D710.Hi all, I've seen this mentioned before but not with any specifics. Does anyone have any detail about what actual usability is lacking in the ftm400 aprs compared with the tmd710ga?
Thanks RockyMountaineer, that helps... to make sure I understand what you mean... it's not the direct in-radio aprs packet send-receive that's the issue/difference, just the lack of directly-accessible built-in TNC, is that correct?What the D710 has that the 400XDR doesn't is a hardware TNC that you can directly access. Thus allowing for a more robust and capable APRS system. For me I am more concerned with APRS thus I run a D710
The D710 has a hardware TNC that is built into the radio that is completely accessible and fully functional by cable and external device. As such you can utilize that TNC to do more then just APRS on the radio. However the 400XDR utilizes a software TNC that isn't as easily accessible or versatile. So both radios will operate APRS natively and both can be used to plot other APRS users on external mapping devices. But the TNC in the D710 is more functional and lets one operate a more robust packet/APRS system if one desires. Example I can run my D710 in APRS mode then go plug my laptop into the back of the control head and run an APRS client (or any packet client) and utilize the radios TNC direct from the laptop. That is something one just can't do with the 400XDR. To some this functionality isn't important. To me it is.Thanks Mathew, that helps... to make sure I understand what you mean... it's not the direct in-radio aprs packet send-receive that's the issue/difference, just the lack of directly-accessible built-in TNC, is that correct?
Where did you mount the antenna on your Jeep? I have an 18 JL and am considering mounting the antenna on the back of my JL up high so the bottom of the antenna will be about the height of the roof. I have the Yaesu FTM 400XDR. For now I’m using it as my base station, but plan on getting another one in a few months for the Jeep.Absolutely!!! more than enough ground plane for any mobile antenna. This is what I have on my Jeep. It works fantastic. Diamond Antenna Dual-Band Mobile Antennas SG7900A
One thing to keep in mind when It comes to mobile antennas is that the ground plane only needs to be the length of the antenna itself. Yes, there is much more to discuss on that topic but I will spare you the boring details. haha. You will love that FTM400. Its is fantastic!
I use a Diamond K400 UHF mount on driver side of hood about 1.5 feet from the window. I have the FTM400 in my Jeep (2012 JKU) I have had it in there for about 3 years and its a great radio.Where did you mount the antenna on your Jeep? I have an 18 JL and am considering mounting the antenna on the back of my JL up high so the bottom of the antenna will be about the height of the roof. I have the Yaesu FTM 400XDR. For now I’m using it as my base station, but plan on getting another one in a few months for the Jeep.
I would happen to second that! I absolutely love the 400. It’s a great radio.The 400 works great. Very user friendly and feature rich. I would do it again given the choice.
Inventor I
20111
I have questioned that as well and have been told that the 300 does APRS and Voice at the same time.The FTM-300 and FTM-400 can also do APRS and voice radio simultaneously, right? That's something that bothers me about my FTM-100, that it doesn't work (so either only send out APRS or voice radio on the FTM 100). Thanks.
