![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/benefactor.png)
Benefactor
- 15,584
- First Name
- Michael
- Last Name
- Murguia
- Member #
0000
- Ham/GMRS Callsign
- KM6YSL
Benefactor
0000
Anything to help you out brother...really love your product!Great. Thank you for the assist!
m
Benefactor
0000
Thank You!Anything to help you out brother...really love your product!
Change your location under the privacy link to 1 kilometer instead of 5. It might not happen right away but it will randomly move you around.Hey guys,
My map shows me as floating in the ocean and there doesn't seem to be anyway to fix that. When I edit my details there isn't even an option to change map location. Any clues?
Hey thanks Nightcrawler it worked. Cheers!Change your location under the privacy link to 1 kilometer instead of 5. It might not happen right away but it will randomly move you around.
No problem brother...we are all here to help in any way we can.Hey thanks Nightcrawler it worked. Cheers!
Have you put in your location under personal details and/or is it trying to locate you from your IP address....you may have it set it to use "My Location Entry" towards the bottom of privacy page. Also I have change the random pin drop to 1Km instead of the default 5Km under the same privacy settings.I am showing about 200 miles from my actual location?
It's not a big deal, but yes. I have it set for My Location Entry and 1km instead of 5km, but it is showing me north of Indianapolis, IN and I am on the Southern Edge across the Ohio River from Louisville, KYHave you put in your location under personal details and/or is it trying to locate you from your IP address....you may have it set it to use "My Location Entry" towards the bottom of privacy page. Also I have change the random pin drop to 1Km instead of the default 5Km under the same privacy settings.
Strange...I know I have read somewhere @Michael telling members to log out and clear cookies to try and fix problems. Have you tired that...its not something I like to do often because clearing cookies means clearing everything but that might help.It's not a big deal, but yes. I have it set for My Location Entry and 1km instead of 5km, but it is showing me north of Indianapolis, IN and I am on the Southern Edge across the Ohio River from Louisville, KY
I will try it at home on another PC first. I am the same way with clearing the cookies.Strange...I know I have read somewhere @Michael telling members to log out and clear cookies to try and fix problems. Have you tired that...its not something I like to do often because clearing cookies means clearing everything but that might help.
HeyShouldn't my map pin be green? I thought that when the member looked at his own pin, it would be green so that it's easy to spot yourself on the map...? Mine is yellow like most others...
Intersting. When I joined the forum, I showed up black. When I became a member, it turned Gold, but recently turned back to black (I think after becoming a site supporter). Not that it bothers me either way, but thought I'd point it out in case it indicated some sort of map bug.Hey
I believe it is a different colour from the usual - Black / Gold when you view your own location pin - however I cant tell as being a Moderator my pin is green anyway
Black - Forum Registered
Gold - OB Member
Green - Moderator
Also as @amp asked - Yes the member map updates once per 24 hours - generally at 00:00 (Midnight) PDT
Hope that helps
Same issue hereAny reason why everytime I click the Member Map, it sends me to a page to order another Membership Badge? Am I doing something wrong?
