![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/ntrailblazer1.png)
Trail Blazer I
Trail Blazer I
Pros and cons LifePro4 batteriesWhat are the pluses and minuses of the Lithium Iron Potassium batteries?
Pros:
Cons:
- Lighter than AGM or Lead Acid Battery of the same Amp Hour rated battery
- More usable energy without damage to the battery (translates to longer use cycles between charges)
- Flat voltage drop through 95% of the battery discharge rate
- Easy to add solar recharging
For Overlanding a hybrid battery system is your best bet. Replace the starting battery with a good quality dual purpose marine deep cycle battery, and add a Lifepo4 battery as an auxiliary battery inside an insulated box (preferably inside the cab with vents to the outside). You want your cons on a battery all to them selves, as LEDs and fridges cause RFI that your com devices can and will pick up.
- Expensive compared to conventional batteries
- Need special charging equipment
- Temperature sensitive
- Can’t be used as a starting battery
I personally have two Marine AGM batteries mounted under my hood. One is the vehicle start battery, the second is for lights and fridge. I then have a 50 Ah Lifepo4 mounted inside the cab for my coms.
Trail Blazer I
Nice summary and thanksPros and cons LifePro4 batteriesWhat are the pluses and minuses of the Lithium Iron Potassium batteries?
Pros:
Cons:
Thanks for the heads upJust an FYI, Dakota Lithium now has starting batteries
Lithium starting batteries have actually been around a long time. I cant remember when I first saw them but I'm thinking late 90's. They were very expensive but had the same output as your Lead Acid in half the space. The couple of people I saw with them fit two in the normal battery tray. Years later I didn't see them any more. Now that I understand Lithium's better, my guess would be lower life span due to 13 volt charging, extreme heat and cold or just cost.Just an FYI, Dakota Lithium now has starting batteries
