Well i dont know then, they can figure it out. All i know is after the dealership oil change this happened and the only thing ive screwed with electrically is wiring the led light 12v to the trailer brake light fuse acc on, grounded at the chassis on the radiator crossmember where it says accessory ground next to ground bolt, the lights worked just fine, i figured though maybe i messed it up but i see no reason the trailer brake light wiring would be on circuit a of the pcm which is where that code says the problem is which should be the trottle pedal, fuel pressure sensor, oil pressure sensor and ac clutch
