JKU lift debate
Nomad_JK
VA, USA
C
Alright guys, I have a debate and was curious what y’all thought. So I’m in a 4-door JK. My original plan was to go a TF 3 in and 35s. The rig came with a Garvin adventure rack. I’m not the biggest fan of it personally but I already have it so why not. The thing is I commute 43 miles to work and I have to park in a garage and with 35s and the rack it would be tight. So I’ve been toying with doing a 1.5 and 33s. Any thoughts?
Captain Chaos
No
No
No
I run a teraflex 2.5” and 35s. I have a Frontrunner rack and I can still squeeze into my garage when need be. The Garvin is a couple inches taller. I wouldn’t make it into the garage with it. But I have never had any problems with parking gearges, most have at least 7 foot clearance around here.
Reactions: Nickzero
Nomad_JK
VA, USA
C
Yeah, that’s my only complaint with the Garvin. Not knocking their product or anything. But i would’ve went with their wilderness rack or a Gobi if I was buying that style. But yeah, ours is right at 7. I’m just squeamish since I ripped the soft top off on my old TJ in Hawaii haha. The other big thing is the commute to be real.
Captain Chaos
No
No
No
I bought a Garvin used for another project. I wasn’t real impressed with it. I like the Frontrunner, but choosing between it and a Gobi or Rhino Rack was tough. Personally, I don’t like the way the Garvin or Gobi hang off the sides of the Jeep in the back. That was my deciding factor. I do drag an antenna or two in parking garages, it happens.
Jedi
Arlington, WA, USA
Brie
McClory
K6JDI
I am a firm believer in function over fashion. Do you find that you need the additional 1" of clearance that the 35's offer over the 33's? If the answer is "no" or "not really" then you should move to 33's. Similarly, are you pushing your articulation to the max, necessitating a 3" lift? If not, then I would consider a smaller lift.
Reactions: Dilldog
Nomad_JK
VA, USA
C
Yeah, I wouldn’t have bought the one I have. But unless I find someone who wants it, it’s not really a priority in changing it until after I get other stuff done. Hell it won’t fit in garages in DC already anyway haha.
Nomad_JK
VA, USA
C
That’s a valid point. My main focus so far was more balancing capabilities I could potentially do with the fact it’s a daily. Not necessarily solely looking at what’s needed now.
Nomad_JK
VA, USA
C
I found a spot at work that had 9ft clearance so since height isn’t an issue anymore I decided to go 3.5 and 35s buuuuuut VA hit me with taxes for a truck I totaled that they never took off my record apparently. So that’s all gonna wait a bit more
  • Sad
Reactions: Kimmar
Captain Chaos
No
No
No
I’m glad you got that sorted out. Someone always seems to standing by with their palm up.
Nomad_JK
VA, USA
C
Yeah, my first Jeep was easy, it was Hawaii, living in the barracks, no bills or anything. Being older and daily made me have to think more into it haha
Nickzero
Greenville, SC, USA
Nicholas
Dugdale
I will seconds the Teraflex 2.5'' spring lift. It's a kick ass lift that feels stock considering you get the Fox 2.0 shocks or similar. I am also on 35's and this lit as done it all.
Nomad_JK
VA, USA
C
Good to know man. Thanks!
Reactions: Nickzero
MLGrace
LAKESIDE AZ
Grace
Army Veteran
I also have the teraflex 2.5 but the rears were a little soft because I haul an expedition trailer and was getting sag. Traded out the rear sprigs for OME. Not as smooth. The teraflex is a wonderful kit however. We have installed three of these and can get it done ina couple of hours in the driveway.
Nomad_JK
VA, USA
C
That’s good to know! I tow my bass boat a lot. Now overall not that much weight but still something to consider.
jeepers29
Georgetown, TX, USA
I had this same issue after towing our teardrop. I went to the Teraflex 3" overland springs to handle the extra weight of the teardrop and RTT.
Reactions: MLGrace
Booboodmb
Center Barnstead, Barnstead, NH, USA
Anthony
Palmieri
Another thing to consider is regearing if you go to 35s. I went with 4.88 and I’m able to use 6th gear again. Life is much better with this gearing. If you are towing, I’d consider going 5.13.
In addition, you have to eventually upgrade the driveshafts on 3.5 lift. Something to also consider.
Nomad_JK
VA, USA
C
Yeah I got you. I have 4.10s now and it’s not terrible. But I haven’t towed my boat yet. We’ll find out how that goes in a couple weeks lol.
And yeah the driveshafts are already on the list just haven’t pulled the trigger yet.
USStrongman
Lubbock, TX, USA
Bryan
Hildebrand
I went in a slightly different direction. AEV 2.5" Dualsport with Kenda Klever 35/10.5/17 tires. When mounted they are 34" at 31psi on AEV Saltas. I run the EAG gutter mount rack. I'm 300lbs and travel with my 172lb great dane/bull mastiff... so on RTT for me.
I ran the AEV 2" spacer lift and 33" Patagonias M/T's which are 33" tires. Just wanted more.
The determining factor really is how much clearance do you need? Stock rigs are capable of so much before we start messing with them. I added mine due to New Mexico and Colorado trips needing the clearance.
Nomad_JK
VA, USA
C
Sorry for the late response. My app has been messing up.
Nah you’re completely right. I don’t need the clearance as much around here but on the long camping hunting trips back in Bama it’s a plus.
Reactions: Billiebob
