Never heard of the air bag deal.. pretty much already have everything else on the list, and experience with it. But the Bull Bag, I'm going to have to look into that.
Theoretically I guess it would. But with as cheap as a decent 20k strap is I would just go that route instead of trying to double up.Great thread and recommendations. Thanks for putting it together. I do Have a question.....I inherited 2 straps with a max load rating of 6500 lbs...if I use them both at the same time, does that double the max load to 13ooo lbs. Really really curious.
Well then....it's off to the store.Theoretically I guess it would. But with as cheap as a decent 20k strap is I would just go that route instead of trying to double up.
Benefactor
In theory, yes that doubles to 13K. But what kind of straps are they? Recovery straps are elastic, and stretch between 10-15% when pulling a stuck rig out. They have no metal hooks or loops. They are all fabric with reinforced eye loops. How long are they? Generally you want something between 20-30'. A KERR (Kinetic Energy Recovery Rope) like the Bubba Rope is designed to stretch upwards of 30% during a pull.Great thread and recommendations. Thanks for putting it together. I do Have a question.....I inherited 2 straps with a max load rating of 6500 lbs...if I use them both at the same time, does that double the max load to 13ooo lbs. Really really curious.
Thanks for the info. This is helpful. I'll check out your recommendations.In theory, yes that doubles to 13K. But what kind of straps are they? Recovery straps are elastic, and stretch between 10-15% when pulling a stuck rig out. They have no metal hooks or loops. They are all fabric with reinforced eye loops. How long are they? Generally you want something between 20-30'. A KERR (Kinetic Energy Recovery Rope) like the Bubba Rope is designed to stretch upwards of 30% during a pull.
With that low rating, I highly doubt they are designed for recovery. Or if they are, it's for an ATV or side-by-side. Even then, 13k isn't enough for a recovery strap for a 4x4 vehicle. Depending on the GVWR (Gross Vehicle Weight Rating) of your rig, you want a strap to be rated around 3-4x that rating. Typically this falls around the 20,000 - 25,000 lbs. mark.
Grab an ARB strap and a couple of metal 3/4" screw pin bow shackles for your kit. I only recommend metal shackles from Van Beest (aka the Green Pin) available at Grainger, or Crosby. Crosby shackles are made in the USA and are about $30 each. The Van Beest shackles are made in Holland and are about $12 each. They both have a Design Factor of 6:1 and are individually tested at the factory. Most other metal shackles are batch tested and have a Design Factor of 5:1.
Thank you for posting this information this answered a lot of questions I had about recovery as a new comer to overlandGreat tips from everyone. Its very important to know where to attach your snatch strap or recovery strap to your vehicle and the other vehicle. YouTube is a great source to see the correct and safe way to use recovery straps. Never ever put a recovery strap over a ball type trailer hitch, that will break the ball hitch and fling it towards the other vehicle. Also never attach the strap to a regular bumper, unless the bumper is made for that specifically. Otherwise the bumper will just come off the vehicle when trying to get unstuck. Always attach to the frame of the vehicle, you can attach to a trailer hitch that is attached to the frame of your vehicle. And lastly when using recovery straps, have everyone but the drivers out of the vehicle and away from the recovery operation in case the strap breaks or something on the vehicle breaks and becomes an airborne object, like a slingshot, that could hit and kill someone. Be safe.
Sent from my iPad using OB Talk![]()
Got to love the Aussies!
Benefactor
Love that video a Jeep pulling out a Toyota ha ha . Great video & good informationGreat tips from everyone. Its very important to know where to attach your snatch strap or recovery strap to your vehicle and the other vehicle. YouTube is a great source to see the correct and safe way to use recovery straps. Never ever put a recovery strap over a ball type trailer hitch, that will break the ball hitch and fling it towards the other vehicle. Also never attach the strap to a regular bumper, unless the bumper is made for that specifically. Otherwise the bumper will just come off the vehicle when trying to get unstuck. Always attach to the frame of the vehicle, you can attach to a trailer hitch that is attached to the frame of your vehicle. And lastly when using recovery straps, have everyone but the drivers out of the vehicle and away from the recovery operation in case the strap breaks or something on the vehicle breaks and becomes an airborne object, like a slingshot, that could hit and kill someone. Be safe.
I always carry a set of wheel chocks in the truck. First set was part of the tire change kit from LR. They were awesome because they twisted in the middle for more efficient storage. But they were only good for mild slopes and factory sized tires.
Then I got a taller, stackable set from the local auto parts store. They held the 33" tires better but collapsed under heavy winching. I could squeeze them back into shape but they were never the same afterwards.
The latest set is by far the most HD I've owned. They're made of really thick rubber and each weighs a couple pounds. They don't stack because of the inner support structure, but should last a lifetime.
When winching, the anchor vehicle should always have chocks in front of the tires. When using the Hi-Lift, always chock the opposite corner that's being lifted.
To get the stink out of plastic... use a baking soda and water mix and submerse and soak 'em. Works well on new plastic stuff like jerry cans, etc.... I don't see why it wouldn't work for the wheel chocks.I have a pair of heavy black ones that stink to high heaven but I threw them in the back of the truck anyway and will keep them there from now on. I also have cheaper plastic yellow ones but think the black ones would stand up longer. Thank you for your input! Good to know where to place them. I've lots to learn here.
Would a good set of wheel chocks be useful in recovery items to have?
Perhaps with the high lift jack, or upside down under tires to prevent spinning?
Curious to know if anyone carries, or has needed them?
Great question from @Ditch and great info from @4xFar Adventures about usage and @Winterpeg for odor solution.To get the stink out of plastic... use a baking soda and water mix and submerse and soak 'em. Works well on new plastic stuff like jerry cans, etc.... I don't see why it wouldn't work for the wheel chocks.
Benefactor
I'm going to give this a go. Thanks!To get the stink out of plastic... use a baking soda and water mix and submerse and soak 'em. Works well on new plastic stuff like jerry cans, etc.... I don't see why it wouldn't work for the wheel chocks.
