Steward I
This, and this bracket. Not a cheap setup but powertank's brackets are rock solid.Worthington Steel Refillable Propane Cylinder, 4.25 lbs.
Worthington Refillable Propane Cylinder is used for powering RV appliances, grills, and other propane accessories.www.campingworld.com
4.5 gallon or 4.5lb? Those linked above are 4.5lb which is a little under 1 gallon. 4.5 gallon would be like a standard bbq cylinder which is massive for camping unless you're running a heater every night.Obviously it's going to vary somewhat but, generally speaking--how many cooks would you expect to get out of, say, a 4.5 gallon tank using a Cook Partner two-burner? I've always avoided foods that need to be cooked because of time, space and weight considerations , but have decided to give it a whirl...
Sorry, pound. :)4.5 gallon or 4.5lb? Those linked above are 4.5lb which is a little under 1 gallon. 4.5 gallon would be like a standard bbq cylinder which is massive for camping unless you're running a heater every night.
As I understand the math, 1lb of propane should give you about 1 hour of runtime at full blast on a dual 10k BTU stove like the Everest 2 or Cook Partner. I have the Everest 2 and have pulled a full week out of my 4.5lb bottle without issue cooking breakfast and dinner but I still carry a 1lb spare just in case.
Pioneer I
44335
Have you found a place where they will recertify the Viking tank? I have been looking into purchasing on of these tanks but I am hearing in the good USA it is hard to find a place to recert.
Why I chose this:
While there are several advantages to choosing a Viking Cylinders product over steel propane gas tanks, a key benefit is safety. Traditional steel tanks can explode when put under stress (such as a puncture or a fire), but a Viking Cylinders tank will not explode in a fire. Tests have proven that our propane gas cylinders will react with a controlled burnout when in a fire, and bullets puncturing the cylinder do not cause fires or explosions. Mounted with powertank mount.
Have you found a location that will recertify the tank at the 5-year mark?Ok, I've had one of these Viking Propane tanks for almost a year now.
17 Lb TankTechnical Specifications | Propane Tanks | Viking Cylinders
Viking Cylinders are available in four standard sizes, with different capacities, dimensions and two types of valves. Homeowners and businesses can identify the correct cylinder size for their needs in the table below.www.vikingcylinders.com
Summary review, it works great! No problems at all. Highly durable and strong.
Two features that I like the most:
1) I can easily tell exactly how much propane I have every night with a flash light. This is quick simple and as easy as looking at your water level through the side of a Nalgene (although it does need to be dark out). I didn't even really give this feature any credit at the time of purchase but it is by far the coolest part of these tanks!
2) It's just flat out stupid light.
Pioneer I
44335
As long as the tank doesn’t look like it’s 30 years old, I haven’t found a refill place that even bothers to check the tank before they fill it.Have you found a location that will recertify the tank at the 5-year mark?Ok, I've had one of these Viking Propane tanks for almost a year now.
