![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/npathfinder1.png)
When I bought my tj it had one on it and it is in the corner of garage as a coat rack. I use a small bottle jack.
Are you saying they will just break under load, or is that "pop" the sound of them slipping?Both farmers and handymen have figured out long ago hilifts arent the best idea. When will off roaders figure it out? Most of my hilift hate comes from experiences on the farm. If you dont fear the hilift it will give you a reason eventually given you use it alot. Im not saying dont use one just be mindful that it can injure, maim, or even kill you even if you think your doing everything safe, thats usually the most dangerous time to use it when you feel like everything going good then last thing you hear is a pop.
The pop sound is your bones being broken when either pins fail and rig slams to the ground , the shaft fold in half from over 8k being applied, one of the pins getting stuck causing the handle to flail like crazy or the whole rig falls over because your not on level ground or the ground is softer than thought.Are you saying they will just break under load, or is that "pop" the sound of them slipping?
Well that all just seems a little dramatic....The pop sound is your bones being broken when either pins fail and rig slams to the ground , the shaft fold in half from over 8k being applied, one of the pins getting stuck causing the handle to flail like crazy or the whole rig falls over because your not on level ground or the ground is softer than thought.
I sure wish there was a decent set of folding off-road chocks. There used to be one manufacturer but that was discontinued about a decade ago.I also carry wheel chocks and a bottle jack.
Good to hear! I’ve owned one for 16 years but never used it - primarily because I find it’s packed size a huge PITA to pack in a small-mid sized SUV. I’ve been thinking about making a small deck where I could slide it, my privacy tent & my Tiregater underneath everything.The ARB BushRanger X-Jack is legitimately the best piece of recovery gear I have and is also the most versatile jack I have ever had.
I don't use the bag that originally came with it, I put mine in an old gym bag. My overland rig is a 2019 Subaru Outback so it is smaller than pretty much everything else. My space is even more limited because I have to keep my backseat open for my 90+ lbs Doberman co-pilot. I have a Wilco Hitchgate so I can carry a full-size spare and also because the temporary spare & kit that came with the car was useless once I lifted and went to the bigger tires. Getting rid of that stuff gave me the benefit of a pretty big cavity beneath the rear floorboard. I can fit the x-jack, air compressor, some basic tools, tow rope, jumpstarter box thingy, and some extra tie downs in that space. I'm looking at getting some Front Runner boxes soon to transfer some of that stuff onto the roof because I will soon hopefully be filling that space with some AGM deep cycle batteries to power a fridge.Good to hear! I’ve owned one for 16 years but never used it - primarily because I find it’s packed size a huge PITA to pack in a small-mid sized SUV. I’ve been thinking about making a small deck where I could slide it, my privacy tent & my Tiregater underneath everything.
