The Mr. Heater is on sale right now for $55 bucks at Bass Pro Shops. I just picked 1 up and am testing it right now as I type. Puts out a nice am out of heat. Should heat up the camper shell really good.
OB 1643
OB 1643
From what I have read the little buddy only works with the 1lb bottles because it screws onto the top of the bottle.For those with the Mr. Heater Little Buddy Heater, could it be fitted to a larger bottle? Or is the 1 lb the only option? On the larger heater, could some one tell me the approximate size/weight?
My good friend Bob Seaborn from Compass Adventures in the UK who specialises in Trips to the Artic circle swears by the Tentipi with a frontier stove, reckons it keeps you toasty even when it is 40 below.If you go with a canvas tent (which I did) you can put in a little wood stove. My stove is on order.
https://www.anevay.co.uk/outdoors/gallery/the-frontier-plus.html?page=2
Do you run that all night while camping? What is the power consumption for that?I'm using a Honeywell 360* surround space heater for my Suzuki sx4 when I'm camping. I picked this up from Walmart for 30$ This is a great little heater!View attachment 12148
I have ran this heater for several hours without any problems, the heater has a shut off built in once the temp reaches its set temp it shuts down. When the temperature drop it kicks back on and this little heater also has a tip over feature that will shut it off, as far as the power consumption I couldn't tell you.Do you run that all night while camping? What is the power consumption for that?
So you simply run this off an inverter plugged into the vehicle, what size inverter? That sounds like a pretty simple and easy setup. I might have to pick one up and do a battery test drain with a meter.I have ran this heater for several hours without any problems, the heater has a shut off built in once the temp reaches its set temp it shuts down. When the temperature drop it kicks back on and this little heater also has a tip over feature that will shut it off, as far as the power consumption I couldn't tell you.
That will kill your battery(s) pretty quick.So you simply run this off an inverter plugged into the vehicle, what size inverter? That sounds like a pretty simple and easy setup. I might have to pick one up and do a battery test drain with a meter.
Lol, ya I wish all the campsites we go to had hookups. Most of the built up campsites in California that have hookups are flooded with huge RVs with generators running day and night. I use a Iwatani butane heater made for indoors with safety features.That will kill your battery(s) pretty quick.
You can use an adapter hose to attach it to a full size tank. The heater is a high pressure style one, hence the 1lbs bottles. The hoses can be picked up at most home improvement stores, walmart and online. Its the same one you'd use to run your typical Coleman camp stove off of a 20lbs tank.For those with the Mr. Heater Little Buddy Heater, could it be fitted to a larger bottle? Or is the 1 lb the only option? On the larger heater, could some one tell me the approximate size/weight?
Just make sure you have a carbon monoxide tester in the cab for safety. You'll also need a window cracked to vent.I will be testing out the Mr. Heater this weekend on a trip up to the UP. Fortunately for me it won't have to be tested to extreme lengths as the forecast is calling for around mid 40s for the weekend. None the less it will be heating up my jeep. Thanks for all the replies guys
Sent from my SM-G930V using OB Talk mobile app
