Search out the Grits and Gravy on the Echolink app. Should be able to search the node # too I think to find it. Then just hop on and check in! Look forward to having you onboard!
That's still the time and place Dan. Hope you can make it Friday!The approval from Echolink came through in the time it took me to write that last post. So that was quick. Now to see if I can make the next net.
Is this still the time/place?
Copied from 12PoundTest above:
USA Grits N Gravy Echolink Conf and Allstar Node 41130 - Live Audio Feed Web Player Live Audio Feed
I'm able to find the USA-GNG in the Echolink app, but I'm not able to connect to it. Is it the sort of thing that has to be turned on?That's still the time and place Dan. Hope you can make it Friday!
Ed
Contemplating this a bit more, I tried disconnecting from the office wi-fi network. I am wondering if I don't have a sufficiently public IP address or some firewall rules about receiving the UDP ports that Echolink uses. (I tried with the EchoHam client on my laptop as well to no avail.)I can get in through W8ILL just fine (just tried it), but I typically cannot get into the GNG server directly.
@desl when you search for GNG do you see a W8ILL showing connected to the GNG server?
I'll probably try again when I get home to see if it works there. (I can control the firewall there and make adjustments).
Thanks for the help!
Traveler II
12189
Traveler II
12189
I thought the repeater link went well Mark. If it's not a hassle for you I'd encourage continued linking. Sorry to hear about the back, those back roads will get you. Take care!By the way, the only reason it took me more than a few hours to unpack and clean the truck after my last trip was because I jacked my back up really bad. But Matt (KN4MMA) likes to give me static.
Let me know if you guys want me to keep linking up my repeater here. I'm more than happy to, even though there aren't many off-road oriented guys here. But there are a few.
N0IV
Traveler II
12189
Provided I'm home on Friday for the net, I'll keep linking it up. There'll be the occasion that I'll be off grid or otherwise unable to link it. I've setup a remote access page via DNS so I can access it anywhere I have an Internet connection.I thought the repeater link went well Mark. If it's not a hassle for you I'd encourage continued linking. Sorry to hear about the back, those back roads will get you. Take care!
That sounds about right. Hang in there!Provided I'm home on Friday for the net, I'll keep linking it up. There'll be the occasion that I'll be off grid or otherwise unable to link it. I've setup a remote access page via DNS so I can access it anywhere I have an Internet connection.
And amazingly, the roads didn't get my back. Destroyed it in the military, and threw it out this past time by sitting in the bed and drilling through the end caps to install bed stiffeners. Had about a solid week where I could barely walk, and was sleeping on the couch because laying in bed hurt too much. Having a bad back sucks. A lot. But that's what's awesome about vehicle based exploration and camping; if I don't do something stupid, my back can handle it and it let's me get out still.
