Full size rigs! who's got em?
Trail_pilot
James
Girard
Hey Full size peeps! who's got what? what would you change and what do you love? I may be looking at building a full size rig down the road but likely not for at least a year of 2. That said it will likely end up much like my Jeep and be able to tackle a moderate to difficult trail ( middle of the road type deal but rocks and water crossings) to get to where I want to go camping. I have been leaning towards older Tahoes or Suburbans, even Explorers. maybe a Cherokee or 4 runner would be big enough but I have a thing for older Blazers/Tahoes as I went through some tough times with one in the past and miss it.
Show me what you got!
BCMoto
SF
Agloro
Hi James welcome there is a full size section for us. I do have a silverado crew cab with a standard bed, the next thing im thinking about is changing out my lift kit for a bigger one
Reactions: Trail_pilot
Blue line overland
Local Expert Arkansas, USA
Hope Mills, NC, USA
Edward
Flores
Love the full size rigs. I got a 97 suburban with a 3 inch body lift for now to clear the 33's. A pioneer platform roof rack with a smitty built xl roof top tent/annex. Led bar light/ditch lights. Still a work in progress. Looking to build a pull out kitchen and up grade the suspension.
Ceg
Selah, Washington
Clay
Graham
US Army
I used a K5 Blazer for over 20 years. I used a few different Suburbans over the years. I use a F350 and Lance Camper now for pavement adventures. I also use it to pull may car trailer with one of my Jeeps for base camp adventures. I am working on replacing the camper with a shorter lighter newer one.
Trail_pilot
James
Girard
I had a 1500 blazer and a pathfinder before I got into Jeeps. That was probably 15 years ago almost. I miss having the space but the Jeep was able to tackle he trails I wanted a little better. Now with a growing family I think I need to get back into a full size rig.
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
View attachment 172726View attachment 172727
A smaller wheel base is definitely better for maneuverability and rock crawling, at least that's what I'm assuming. There's 5 of us in my family so full size works better for us, I just have to be more choosy on trails.
Trail_pilot
James
Girard
Ya I will have to do the same. And get used to taking things a little slower too.
Reactions: RoarinRow
BCMoto
SF
Agloro
Sometimes the longer wheelbase helps you over stuff but short wheelbase helps ypui turn around easy. When I go out with my jeep buddy I have to back out most times
janders
Seattle, WA, USA
Jason
Redacted
I spend a lot of time backing down trails that I have no business being on. But we throw a queen sized mattress in the back of this diesel pig and whenever we put it in park, camp is made. And I sleep better in the back of this truck than I do at home.
haaken675
fl
Large
J
Very happy with my f150. Full size is great for accept for tight trails. Only problem on tight trails is if your vehicle is new enough that you don't want to scratch the paint then it kinda sucks. I think that goes for any newer rig though. We are a family of 3 going on 4, with 2 dogs. I am not sure at this point how i would fit everyone in something smaller...
Trail_pilot
James
Girard
I love the full size life. Super comfy while driving with plenty of room even with 4 people. Not only that but fully loaded I’m still within gvwr(if it’s just the wife, myself, and dog).
Ya I never really though about gvwr. I really should weigh my the lol. It's probly close when empty lol.
Reactions: PonoAdventures
DevilDodge
Altoona, Pennsylvania, USA
David
Spencer
GVWR is the max weight at which your brakes, steering and suspension are rated to perform.
Payload is the suggested number for stuff you can add to, load in...including passengers.
Curb weight is your empty vehicle with full fluids...so a full tank of gas.
To easily find your curb weight...take you GVWR minus your payload.
Using the door stickers if your vehicle ia new enough
For instance my HeftyDuty has a GVWR of 10000lbs. A payload of 2998
So my curb weight is 7002 lbs.
There so a bit of capacity over GVWR...check your axle ratings...mine is 5500 front and 6000 rear. But you also must remember some of that capacity is for inertia...weight transfers to the rear when pulling out and to the front when stopping.
The important thing is to make sure when you load you do not remove too much weight from the front. This is why a truck has a rake to it...and why I do not like level kits.
