Educator I
your absolutely right. ECM doesn't detect enough O2 in the stream and in return the ECM just dumps fuel into the system that remains unburned and flows down stream making a royal stink, horrible mileage and poor performance overall.Injector can but biased lean o2 usually doesn’t. It sees its lean and computer makes up for it by dumping fuel. Check to exterior leaks first. Then internal leaks. Injectors. Then look at o2. If you have a scanner data can confirm a biased o2 fairly quickly.
Josh
