2020 Jeep Wrangler Rubicon Unlimited
38,xxx miles - around 9700 miles a year
2.0 litre, 4 cyl engine with 8 speed auto transmission
Has a factory extended warranty, too.
This is a complete package. Single owner, custom order. Has the low maintenance cloth seating, aux switches, rear back up camera, a/c, power door locks, windows and mirrors. Full Rubicon package with factory skid plates, 4.10 gears, locking differentials and sway bar disconnect.
This Jeep has an upgraded Rubicon Express suspension (1.5” lift) and JKS greasable sway bar full disconnect end links. Stock Rubicon wheels hold 35x11.5x17 Maxxis RAZR AT tires (hugely popular in Australia).
The factory steel bumper group was ordered and the front bumper has a Smittybilt 9k winch (remaining with the Jeep).
Upgraded lighting includes high and low mounted LEDs in the front, rock lights under the bumpers and body, and a set of LED rear flood lights that double as chase lights. Jeep has the factory LED lighting option as well.
Also factory ordered was the cold weather package (heated seats and steering wheel), and the factory tow package (7 pin connector and upgraded cooling and alternator).
Inside, the rear seat has been deleted in favor of a flat load floor with tie downs. Easily removed and replaced with the original rear seats if desired. The underfloor storage has been preserved, and the fridge slide mounts securely to the new floor. Plenty of under-floor storage on the original footwells. The 48 quart fridge-freezer will remain with the Jeep.
Under the front seats is the Kraken air inflation system built around an ARB twin-pump air compressor. Very powerful. This system will remain with the Jeep.
On the dash is a 67 Designs accessory rail. This has mounts for a phone, a Ham radio/GMRS and a dedicated mount for the Garmin Overlander tablet (which will remain with the Jeep). There is also a hood mounted low profile GMRS antenna which is wired into the center console.
The roof rack is from Rhino Racks and is mounted to the interior frame of the Jeep. It is capable of managing an 800+ pound static load, so the Smittybilt hardshell rooftop tent is a breeze. This actual tent is the last of its kind and is brand new. It comfortably sleeps two adults. The width of the mattress is almost 55” and the length is around 6.5 feet. The tent stays with the Jeep.
The awning is a Darche Eclipse unit from South Africa and is an aluminum-framed 270 degree unit. It does not have the wall kit, but the awning stays with the Jeep.
This Jeep can easily manage the daily commute, and get you hundreds of miles into the back country on the weekends.
