Wondering what everyone is running as far as navigation with tracking. What do you recommend & why?
Sent from my LG-D851 using OB Talk mobile app
I have looked at this one, I wish they had android supportI've been using the MotionX app on iPhone to record my tracks. Its pretty inexpensive and has worked flawlessly.
http://gps.motionx.com/
With this garmin can you download tracks to it?I usually keep a Garmin etrex by the windshield. Tracks my movement and I can mark points to go back too. Nothing fancy at all, but it does the trick
Sent from my SAMSUNG-SM-N920A using OB Talk mobile app
Expedition Master I
1537
Love it. At some point I plan to pick up an inReach SE to take the place of my Dual 150 external gps. I don't need/want the Explorer since I only use it for my iPad which I generally run Gaia and Scenic Map on. For the price the Dual 150 works fantastic, has great battery life, and is VERY small. It's actually charging inside a small cubbyhole in this picture.The Delorme (now Garmin) inReach Explorer with an iPhone 6 Plus, rocks! Just download all maps to your phone or tablet and you are good just about anywhere with the Earthmate, or GAIA apps. Of course the added piece of mind that you have a two way communication SOS beacon device that works via the Iridium satellite system is just the icing on the cake! Just got it setup so I haven't tried the tracking feature yet. What's really cool is it allows you to post your GPS location to a webpage or social media where your friends can follow along with you while out on the trail.
You can also use an app called "rammblr" it uses Google maps and tracks your movement so no need to download trails.
Expedition Master I
1537
As I said in my post it's a great little unit. The only reason I'll replace it is to add 2 way communication and tracking.Thinking I am going to go with the Dual XGPS150A for my needs. I like the versatility of using various apps and handheld devices and has no issues off-grid. Where I prefer to be. My pilot friend swears by it.
Can the Dual GPS not be operated with a 2 way communication system? And does the GPS not track? Maybe I don't understand your reply.As I said in my post it's a great little unit. The only reason I'll replace it is to add 2 way communication and tracking.
Expedition Master I
1537
It is only a GPS receiver with no communication abilities. Whatever map software you're using will plot your track but only you can see it.Can the Dual GPS not be operated with a 2 way communication system? And does the GPS not track? Maybe I don't understand your reply
If you need GPS and want to communicate then get a Delorme InReach. If you only need GPS then get whatever you want. The Dual is a good option. The Delorme Units are multi-purpose GPS and Satellite text communications. Plenty of info online about them and some threads here.Can the Dual GPS not be operated with a 2 way communication system? And does the GPS not track? Maybe I don't understand your reply.
Expedition Master I
1537
Yessir. This was also discussed only 8 or 9 posts ago.If you need GPS and want to communicate then get a Delorme InReach. If you only need GPS then get whatever you want. The Dual is a good option. The Delorme Units are multi-purpose GPS and Satellite text communications. Plenty of info online about them and some threads here.
