Compound Turbo 12 Valve Swapped F350 with 2022 Bison Overland Flatbed camper on 37s, King 2.5 coilover 4 link front, alcan/icon 3.0 rear
40,000 miles on motor
25,000 miles on entire drivetrain (trans, axles, 4.10 gears LSD, NV5600, np205 tcase)
223k on odometer
We’ll Start with an asking price of $105k
(Truck and camper will be sold together, not seperating)
**registered and insured as a Motorhome**
Located in Millington, NJ
You Never know what an appropriate asking price is with this stuff. I’m well into 150K+ in the build and unfortunately you never get that money back in this game. All receipts for parts, work, etc. will be available for the buyer.
Due to a growing family and less time to spend “off grid” playing on bicycles, a more Road oriented/RV park type rig is necessary
So on that note I am Open to trades for LARGER Vans with room for bicycles, class B+, C’s such as Winnebago ekko, coachmen crosstrek cross trail 20xg or similar with “garage space” to store bikes inside
This truck will not be for everyone so please read thoroughly if you’re interested and leave the poor comments out of the thread if you’re not.
Feel free to privately message me with any gripes, concerns etc… also feel free to ask any relevant questions you like in the thread and I will do my best to answer
It’s Loud, it’s fast, it’s high, it’s manual, and it will not pass any type of smog inspection, so California need not apply. Although it does run very clean on biodiesel.
It will run forever if properly maintained.
Parts are available most everywhere.
Will run on all the diesel here in the US along with the questionable stuff outside of the country. For that reason there is a FASS fuel system in place for its filtration and water seperation and ease of access and serviceability
Very easy to get back up and running with common 12 valve knowledge if there was a break down
The focus of the build is around Mountain biking off grid. Designed to be as reliable as possible and rip fire roads comfortably and fast more than ride pavement all day long. Please keep that in mind if you’re inquiring on this rig
• 04 Ford F-350 Lariat leather Crew Cab 4x4 Long Bed with Black Powdercoated Custom Flat Bed with Built in Gooseneck under camper
• Rust free rig. Most of its lift spent in Idaho. Garage kept in winter, primarily used summer and fall
• 5.9 12 Valve 64 over 75 Borg Warner Compounds, Swap Was done in 2012 With 165k on the Odometer Before it Was Fully Rebuilt. Every Wear item Changed on Whole Truck... Down to Weather Stripping on Cab.
• 07 Harley Davidson Front End Conversion with •Billet badges Cummins Ford emblem.
• No Check Engine Lights
• Color Matching (Black Obsidian) 08 Mirrors
• Perfect Cream Leather interior
• Cover king Molle seat covers protecting the leather
• Two rear seat deleted for in truck bicycle storage (factory rear seats will be included)
• Motor fully rebuilt around 40,000 miles ago by Jefferson State Diesel
• Fire Ringed Head by Big Twin Diesel with Built Head Mild Cam, 4k gov springs
• KDP mod
• ATS 3 pulse exhaust manifold
• One piece keating design works valve cover, tappet cover
• 60 Lb Exhaust Springs so The Head Won't float When Using Exhaust Brake
• Bored .30 Over and sleeved at rebuild
• ARP 625+ Studs
• Fleece performance coolant bypass
• Mag-Hytek rear Dif Cover
• Amsoil Full Synthetic Oils Throughout
• 25000 miles on transfer case, steering box, 6sp NV5600 with Short Throw Shifter and Expansion Coolers
• Pac Brake PRXB Exhuast Brake
• Quad Pillar Pod- Boost, Pryo, Fuel Pres, Trans Temp
• Protec Boxes Under Flat Bed
• Arb front bumper
• Arb twin compressor
• Bushwacker fender flare, no rubbing
• Come up 16.5k synthetic winch
• Factor 55 fairlead
• LED projector head lights
• rigid led back up lights
• Rigid led amber driving lights wired to factory switch
• Baja designs lp9 fog lights
• KC gravity roof mount light bar and roof rack
• KC side mount light bars driver and passenger
• SPOD bantam switch panel to control it all
• New dual red top optimas
• Noco on board batt maintainer
• Noco onboard waterproof plug for maintainer and block heater
• FASS Fuel Class 8 Semi Truck System
• Amp Full Length Auto Steps
• Every Wear Item In Drivetrain Replaced around 25,000 mi ago
• Kenwood Dash Cam With Full Time On Switch Wired
• Kenwood Excelon Double Din Nav Head Unit with CarPlay
• Back Up Camera W/ Night Vision
• JL Audio 13" Stealth Sub
• JL Component Speakers In Every Corner and Tweeters in Front A Pillars
• 4.10 Gearing with LSD rear open diff front
• Full traction coilover conversion with custom valved king 2.5s
• Warn manual locking hubs (no more vacuum actuated)
• manual idle control knob for cold weather warm ups and heavy winch operation
• Far from stock HD tie rod, drag link, track bar
• Brand new Spicer rebuildable/greaseable HD ball joints to be installed before sale
• Far from stock front diff cover with fox stabilizer
• Custom Alcan rear leaf packs and Firestone bags
• Icon 3.0 adjustable rear shocks
• Outlaw fab rear traction bars
• Black rhino 18x9.5 rims and spare
• Toyo open country RT 37x13.5 tires and spare (25k mi)
• tire rotations every oil change including the spare
• Fresh amsoil oil change performed
Camper was purchased as an insulated poptop shell from Bison overland with insulated poptop vinyl/sunbrella canvass material
Interior was a collaboration with Vice customs and myself to come up with a unique design that fits all the things I wanted.
All perfect CNC cut Bamboo with super unique Torzo surfaces counter tops and table.
Hest dually mattress fits perfectly in the cab over and can be folded in half to Allow for more storage when solo traveling.
Pendleton seat cushions convertible to second bed at dinette area
• 700 watts of solar to a 150/70 Victron charge controller.
• external zamp plug for additional ground panels
• Expion 360 Li batt
• Xantrex 2000 watt inverter charger with multiple interior and exterior 110 outlets
• Smart plug 30amp stainless charge port
• Blue Sea systems combination 12v/110v switch panel with built in breakers to control the entire camper
• Victron smart shunt battery monitoring (all Bluetooth including inverter and charge controller)
• LED lights throughout including red led night lights, led maxxair fan lights and shades, blue led water tank level light and led lights in storage hatches and electric cabinet
• LED exterior porch lighting
• Propane Dometic dual stove glass top
• Dometic glass top sink
• Isotherm 130 drawer fridge freezer
• 12 volt hot water heater
• Bullfinch interior shower port and shower between dinette.
• 30 gallons of fresh water stored inside at front of camper.
• Thetford portapotti Brand New never used
• Multiple 12v, usb and USBc ports throughout
• Dual maxxair fans with remote control for cabover
• Weboost drive reach signal booster with otr antenna mounted to pop top.
• 4 corner roof lift actuators with Hall effect sensors so it lifts and lowers smoothly every time and evenly
• Bundutec hard cover outdoor shower with bullfinch shower port.
• Dometic no leg awning
• Tern overland windows, door, and hatch doors all around.
• Custom built full size spare tire box from Alumline
• All marine grade stainless hardware on cabinetry screws, water ports, wiring, etc.
As I said before this was built as a FAIR weather MTB destination rig. Having a hardwired/mounted heater was not necessary for me. It is more than Capable of being a winter rig. It is very well insulated along with the poptop material. On colder days I had a propex portable heater box that I would hook up to the propane, that was sold shortly after realizing I would not use it.
I am willing to add to the camper at your cost if it is missing something you want or need
There are plenty of open circuits 110 and 12volt to add whatever you like.
The only thing lacking on the rig is Cruise Control.
I never felt the need for it so I did not try to figure out how to get it working with the NV trans.
There is no grey water tank. A collapsible storage tank would be used when needed for sink/indoor shower. None of the camping I did was in rv parks so having a mounted grey water tank was not necessary.
Rig is currently located in Millington NJ
Mileage will continue to go up as I do still use this for some overnighter MTB trips.
Test drives will be aloud for interested parties with funding otherwise I will do the driving if requested.
Because this is titled as a motor home, RV loans may be a possibility but you must inquire on your own.
If there are specific questions photos videos you would like to see please feel free to reach out, we can exchange numbers and go from there.
For Out of state inquires, I will be happy to go over the rig via FaceTime or other form of video call.
I would consider delivering within a reasonable distance.
It is impossible to list every detail of this rig so forgive me if there is anything I missed. I will continue to update the thread accordingly
If you’ve made it this far, thank you for reading and thank you for checking out my rig
-Joe
223k on odometer
• KDP mod
• ARP 625+ Studs
• Arb front bumper
-Joe
