Cummins R2.8 in California
Anak
Sandy Eggo
Given how Kali and CARB works and the challenges that presents, it wouldn't surprise me if both sides are essentially telling the truth.
It may well be that Cummins tried to submit a request, but their request doesn't fit the CARB template. Odds are good there are fields which don't fit this situation. So Cummins sent something, but CARB viewed it as incomplete and sent it to the circular file. After all, you can't expect a California bureaucrat to lift a finger in initiative to help an evil money-grubbing capitalist corporation. So from CARB's perspective nothing has been submitted.
It was 20 years ago when I worked for Hooker. Windows 98 was the hot thing in technology then. I doubt anything was being done electronically then, but I would think it would have changed by now.
bgenlvtex
Texas
Bruce
Evans
My bet is that Cummins doesn't want to try to play ball with the bureaucratic mess that is Kali, but they don't want to publicly admit that either.
Thanks for doing the legwork to show that there is currently nothing to hope for.
This right here, the political climate in Kalifornistan measured against the potential profit to Cummins is going to be totally out of scale.
All it takes is one environmental activist lawyer suing, which will be filed and heard in CA courts and any potential profit will be wiped away in several orders of magnitude.
As long as California continues to elect idiots, I wouldn't expect any of that to change.
But I suppose you could buy an older Jeep and swap the tub, so you are effectively repowering a pre-emission vehicle, since the requirements are based on VIN#
yj4roks
Fallbrook, CA, USA
Chase
K6FWD
THAT...is exactly what I was thinking of doing!
Reactions: bgenlvtex
Yroundrdn
San Diego, CA, USA
Ben
This smog stuff is messy. I see your from SD so this will make sense. My burb has a 454 that wouldn't pass smog in Valley Center because the test is an idle test since the assumption is it would mostly idle in rural farming communities. Thus I was able to purchase it for a scrap price of $300. I was going to register out of state but was told to register it in Poway, wait 3 weeks and re-smog it. It passed with flying colors as a city vehicle, (different test). I also learned that I could have registered in Pine Valley, Descanso or Julian and skipped the process all together. Up to you but it may be the easiest solution and you would not get jacked up for out of state plates down the road.
Reactions: Brewbud and Downs
yj4roks
Fallbrook, CA, USA
Chase
K6FWD
They should, at a minimum, allow case-by-case review. My Jeep is 30 years old and the shitty ECM that was used at the time was only used for about 1-1/2 years. There are no replacements to be found (been searching two years) and mine is not repairable. So far the only CARB legal "turn key" swap I can find is a 6.0L Chevy which I do not want!. Yeah I can tear down a similar year truck and swap over the engine and smog stuff but for the beginning mechanic like me...I will struggle figuring out the wiring, etc. It would be a mess. Not that it will do any good but I am not going to let up with emails to CARB about this crap, imposing a blanket law that no diesels into a gasser are allowed post 1976.
Ontario California
SMR
KO6BI
It's actually not that difficult to do an engine swap here. I've personally done or been involved in 14 to date. All CA legal. They will be expensive though.
bgenlvtex
Texas
Bruce
Evans
You should give the OP some help then, as that is what he is looking for.
To be clear you have deezil swapped or gas swapped, as my understanding is one is verbotten and the other not so much.
bgenlvtex
Texas
Bruce
Evans
Not seeing political charges hatred, just discussed options and problems with solutions for which I appreciate.
Nope, I pointed out that the political climate in CA is responsible for his plight, then subsequently poked fun at it.
I probably should not have done that on this forum.
There however was no "hate" involved, that part is just silly.
JCWages
Grass Valley, CA, USA
Wages
Poking fun is one thing. When you bring sexual orientation or transformation into it then you cross the line. Like I said, this just isn't the place. :)
*edit*
If you didn't intend the post to come across as hateful then I understand and I appologize for calling it out but please try and put yourself in someone else's shoes who can identify as transgender or LBGT in some way.
bgenlvtex
Texas
Bruce
Evans
Sorry for disrupting your cognitive dissonance, carry on.
Reactions: JzzR83
Ontario California
SMR
KO6BI
Gas only. The 2.8 made me look into diesel. A few years later I changed my mind. Engine swapping is isn't bad If you don't need to worry about custom adapters, flex plates...... That's what I was seeing with the 6BT, 4BT swaps. Years later some of these custom adapters broke. What do you do when the guy who made the "kit" has been out of business for a couple of years.
bgenlvtex
Texas
Bruce
Evans
I see, yes.
The problem OP is experiencing is compliance with State government imposed environmental regulations.
His challenge is not mechanical.
