Cpap and overland?
Rubiconcruiser
So Georgia
Hey guys Your Cpap being electric can require as much as 4.3 amps draw depending on your breathing this is difficult to manage without a good inverter and we’re not talking Harbor Freight mine tested out ok but I dropped battery voltage to 10.4 before morning that is a bit too close unless you’re an early riser using solar to charge your battery is ok but really a good generator is a better purchase.
Brentwood, CA
Rubiconcruiser, I've gone five nights and only had my 12v battery at 12.3 volts. I use a Respironics Dream Machine, which is 12v so I don't need an inverter. I also don't use the humidifier or heated hose.
Sent from my SAMSUNG-SM-G890A using OB Talk mobile app
Brentwood, CA
If accurate then that decal is saying the device draws 5 amp hours per hour. So if you are running the machine for 8 hours you would be pulling 40ah. That is pretty high. Therefore you would want a big battery to keep the battery happy and long lasting. Something in the 90-100ah range. You will see this repeated over and over again by me in other threads. AGM batteries as in anything other than lithium-ion do not like to be drained down below 50%. It kills the lifespan of the batteries.
Here's a lengthy discussion on EP: http://forum.expeditionportal.com/threads/172079-CPAP-Power-Questions
Wiring up something like this between your CPAP machine or fridge will give you much more accurate power consumption readings.
T-Trees FT08 RC 150A Watt Meter Power Analyzer With Backlight LCD Hight Precision
by T-Trees
Link: http://a.co/bOIokeo
A fridge, for example, may have a 2.5AH draw. That of course is only when it is running. So depending on ambient temp and fridge temperature setting the amp draw will vary greatly. For the CPAP I would assume the power consumption would be a lot more predictable.
Mine says it draws 6.67 Amps and I use the factory car adapter plugged into a 12v receptacle wired to this battery to get my 5+nights out of it.
ML35-12 - 12V 35AH U1 Deep Cycle AGM Solar Battery Replaces 33Ah, 34Ah, 36Ah - Mighty Max Battery brand product
I put it in a battery box. The 12v receptacle fits inside and I pull it out when needed. The box has a strap around it making it easier to carry. It's a little heavy, but I'm not backpacking with it.
