Pathfinder II
Pathfinder II
Pathfinder II
Pathfinder II
DUDE! I had one of those as a kid!Get "The Animal" Tires! They let you climb where others can't! No need for any traction
devices! LOL...
View attachment 2599View attachment 2600
User Review:Get "The Animal" Tires! They let you climb where others can't! No need for any traction
devices! LOL...
I use traction jack, good product!Tractionjack.com look interesting....
I'm old school, I like simple aluminum sand ladders. They have multiple uses, I 've used them as work benches, tables, a shower floor, as a walk way from vehicle to vehicle, working surface to repair hubs and even as a stretcher once. But the most important thing about them, they are easy to clean, so I'm very willing to break them out and use them. Ive had a set since 2002 they still look good. When you take all this into account, they are a bargain.
My original set I got from a a place that no longer exist. I did buy a set more recently from OKoffRoad. Once upon a time they cost $160 now they are $245, why I don't know, because they are nearly identical to my old ones.Where did you get your sand ladders from? I've been looking for a cheap alternative to Maxx Traxx for now so I have some sort of recovery gear.
They are when you account for longevity and uses. I have yet to find anything for Overlanding that I could refer to as cheap LOLWow 245 guess they are no longer a cheap alternative.
I've seen those recommended elsewhere, as well as the old surplus versions sometimes available. Have you had any occasion to try them with snow or mud? I can see how they would be good in sand, but look like they are too slick for snow/mud. The perforations have the sharp side down, so that doesn't help.II like simple aluminum sand ladders.
You can use them either way really, and they are slick in snow, I've actually slid off the side in off camber and even on straights. One time in sub zero temps my tires froze to them and I couldn't move, took me a sec to figure out what was going on. A little gas took care of the problem, but it was weird. I don't know how plastic would fare in those conditions. In mud they work great, actually even better than in sand. When you are done using them, you stand them up and slam them down, all the much falls off.I've seen those recommended elsewhere, as well as the old surplus versions sometimes available. Have you had any occasion to try them with snow or mud? I can see how they would be good in sand, but look like they are too slick for snow/mud. The perforations have the sharp side down, so that doesn't help.
You don't really need all that, the weight of the vehicle and the grit from the sand or mud provide all the traction you need. And because they are metal, you can spin on them and only put really funky swirl marks on them. Honestly about 90% of the use they get is in roles other than for getting me unstuck. The way I most often use them is as flooring when I go out in the woods and it rains, or as little paths between vehicles. I consider them flooring I can use to get unstuck rather than the other way around.Could add screws to the bottom side cut of the tops as to not hurt your tires. then they would dig in more. Or weld on some cleats of sorts
