You would link it w/ something called a Luna satellite burner, and then pair it w/ any jet boil cup, pan, etc...Chris does the jetlink work with a jetboil flash for example?
-Chris
Ok thanks for the reply. I am kind of learning, it seems the jetboil cups are also sold with their own burner.You would link it w/ something called a Luna satellite burner, and then pair it w/ any jet boil cup, pan, etc...
-Chris
No problem. It's great if you're cooking for more than 3-4 people. I use it for my family of 5. Jet boil is connected making me coffee while the bacon and eggs are working on the eureka stove. The simmer control on the eureka is great.Ok thanks for the reply. I am kind of learning, it seems the jetboil cups are also sold with their own burner.
Thanks for the info on this stove, I love the idea of having one propane source to power the stove and jetboil. I do the same, Jetboil for coffee while making breakfast on the stove. Simmer control is an issue with my Coleman, so it's good to hear this one simmers well.No problem. It's great if you're cooking for more than 3-4 people. I use it for my family of 5. Jet boil is connected making me coffee while the bacon and eggs are working on the eureka stove. The simmer control on the eureka is great.
Also, I've noticed when shopping for camping or outdoor stuff, if I add my items to the shopping cart online, then leave the website, I usually get an email with a discount code if I come back and complete my order.
-Chris
Looks like my stove that my father gave me. 1960's Coleman White Gas stove.1960's Sears stove I got at a yard sale for $8. Looked like crap. Sand blasted it, painted it, and it's my favorite stove by far now. Way out preforms propane in cold and high elevation. A couple friends were making fun of my 1960's stove on the Rubicon a few years ago, but it was November and got into the teens at night, at high elevation too... and none of their fancy propane stoves would do anything but blow liquid propane out of them in the morning. Guess who's "goofy" old stove made them all coffee that morning. :)
Before:
I just used my Eureka for the first time. It worked well and could control the burner well. Only negative, was I couldn't get the igniter to work and had to lite it with a lighter. It was a little breezy. I could see the spark but it wasn't lighting.Thanks for the info on this stove, I love the idea of having one propane source to power the stove and jetboil. I do the same, Jetboil for coffee while making breakfast on the stove. Simmer control is an issue with my Coleman, so it's good to hear this one simmers well.
-Dave
Thanks for the info. The ignitor is definitely not a deal breaker for me, frankly, the ignitors never work for me on anything, except the Jetboil!I just used my Eureka for the first time. It worked well and could control the burner well. Only negative, was I couldn't get the igniter to work and had to lite it with a lighter. It was a little breezy. I could see the spark but it wasn't lighting.
What was the ambient temperature? I've noticed in sub 40 degree weather, I have trouble getting the farther burner to ignite but usually after letting the gas run for 20 seconds, and about 4-8 clicks, they both ignite.I just used my Eureka for the first time. It worked well and could control the burner well. Only negative, was I couldn't get the igniter to work and had to lite it with a lighter. It was a little breezy. I could see the spark but it wasn't lighting.
Thanks , for the info. I was just debating the Eureka stove bag to transport and protect it. It was warm out perhaps 75 degrees, slightly breezy.What was the ambient temperature? I've noticed in sub 40 degree weather, I have trouble getting the farther burner to ignite but usually after letting the gas run for 20 seconds, and about 4-8 clicks, they both ignite.
I should also add that I ignite the closer one first, then the second.
How do you transport your stove? I found a decent box at Walmart that fits the stove, fuel cans, and a few other things perfectly for my trips. I'll try to post a pic later tonight.
-Chris
Yeah the igniter on the burner that comes with a jetboil is directly over the gas output.Thanks for the info. The ignitor is definitely not a deal breaker for me, frankly, the ignitors never work for me on anything, except the Jetboil!
What keeps the stove secure in the case? It kind of looks like the hatchet is wedged between the stove and case, holding it secure?
I assumed you had to use the Luna burner because it runs pure propane whereas the rest of the Jetboils use the isobutane/propane mix?Yeah the igniter on the burner that comes with a jetboil is directly over the gas output.
Side note; the burner that comes with say a jetboil "Flash" won't work with a Eureka stove. A jetboil Luna satellite burner will work and excepts your jetboil cup. I am sure the company could make an adapter but then fewer burners would be sold. ;-)
I think any of the burners can use either fuel types. I am not an expert though. The Luna burner looks identical to the jetboil ones. Just different connection. It's made specifically to connect to a stoves fuel output.I assumed you had to use the Luna burner because it runs pure propane whereas the rest of the Jetboils use the isobutane/propane mix?
Got it, yeah, I'm no expert either and you are more of expert then me as you actually have it!I think any of the burners can use either fuel types. I am not an expert though. The Luna burner looks identical to the jetboil ones. Just different connection. It's made specifically to connect to a stoves fuel output.
Sorry, I usually have the rest of my cooking stuff in there. Plates, forks, frying pans. It's fairly snug when I pack it up. I got it because I could stand the stove upright, which as you can see. It sits nicely.What keeps the stove secure in the case? It kind of looks like the hatchet is wedged between the stove and case, holding it secure?
Ok, I just wanted to make you aware of what worked with the Eureka stove because I bought a jetlink to then later bought a Luna so I could use my jetboil cup. Didn't want anyone else making that mistake.Got it, yeah, I'm no expert either and you are more of expert then me as you actually have it!
Appreciate it!Ok, I just wanted to make you aware of what worked with the Eureka stove because I bought a jetlink to then later bought a Luna so I could use my jetboil cup. Didn't want anyone else making that mistake.
You may want to check your control stem. I've had great luck controlling the temp on my 5 stoves. Sometimes it can also be that there's not sufficient pressure in the tank, I have had that trouble before as well.I have used the Coleman stoves a lot. My only complaint is that they are hard to control the flame (either full blast or nothing). Pretty good bang for the buck though.
