Oh my, at what point in your life does this happen or you let it to happen? An hopefully it doesn’t start with choices in off-road tires
Duratracs should have zero issues on a wet road. Something else is wrong. I could see the OEM GM versions being bad due to an OEM compound spec or something hinky, but the aftermarket DT's are one of my go to choices for a snow tire.So what is everyone running on full size trucks? Like I stated above looking for a better tire on wet roads than the Duratrac. My 2011 F-150 Supercrew FX4 weighs roughly 6000 lbs with all the gear I keep in it regularly under the Diamondback cover.
What do you drive? Not the case with my F-150 and light back end, on cement or straight black top roads I have no problem. But on the blacktop roads with crushed sea shells mixed in with the blacktop I spin the tires with very little acceleration if the roads are wet. If I turn a corner and accelerate too fast the rear end will break loose and I'll end up sideways. I grew up in SE MN so I know how to drive on icy roads and this is exactly what the sea shell infused roads act like when it rains. I haven't spun out and ended up sideways because I know to let up on the gas and not brake. My son born and raised in Florida started driving and didn't know this and he spun my truck sideways with me in it, luckily no traffic was coming from the other direction. I laughed and said you just got a lesson in driving on icy roads in Florida! Just looking for another solution that might handle these roads better, not to mention the Duratracs are overpriced IMO.Duratracs should have zero issues on a wet road. Something else is wrong. I could see the OEM GM versions being bad due to an OEM compound spec or something hinky, but the aftermarket DT's are one of my go to choices for a snow tire.
The Cooper ST Maxx is similar to the DT, but better in every way for a fullsize. STT Pro's are my favorite tires.
Granted I am just talking about my crappy standard tires that came with the Silverado and not the ones in discussion, but if I roll into it any slower I'll be going backwards.You got to roll into it easier, before punching it. Allow the truck to transfer some weight to the rear tires first.
Pathfinder II
Pathfinder II
Wow. That’s ugly.The KO2s were in the running for replacing my Toyo AT Extremes, which I hate. But last week on a trail ride, my buddy sliced to steel 3 of his brand new KO2s on a 7mi trail, while the Toyos, an older set of BFG ATs and MTs did just fine. My tires rarely see pavement. Usually tire-eating bull rock. We live in the woods and have to keep the roads open ourselves. After seeing how vulnerable the sidewalls are, I wouldn't feel confident getting down the mountain.View attachment 114768
Think skinny. Wide tires are built for floatation. The LAST thing you need in rain.looking for a better tire on wet roads
But they are not flat ??The KO2s were in the running for replacing my Toyo AT Extremes, which I hate. But last week on a trail ride, my buddy sliced to steel 3 of his brand new KO2s on a 7mi trail, while the Toyos, an older set of BFG ATs and MTs did just fine. My tires rarely see pavement. Usually tire-eating bull rock. We live in the woods and have to keep the roads open ourselves. After seeing how vulnerable the sidewalls are, I wouldn't feel confident getting down the mountain.View attachment 114768
Nope, they were cut to the steel, but not flat. He made it home, but had them replaced immediately. He got one replaced under warranty, since he had 30 days to buy the road hazard warranty and the tire shop hooked him up if retroactively bought 4 warranties.But they are not flat ??
I gotta say, this is driver error.while the Toyos, an older set of BFG ATs and MTs did just fine
Sounds like a testimony to stick with BFG KOs !!Nope, they were cut to the steel, but not flat. He made it home, but had them replaced immediately. He got one replaced under warranty, since he had 30 days to buy the road hazard warranty and the tire shop hooked him up if retroactively bought 4 warranties.
No one else had the same tire. I had old, workout Toyo Extremes, other guy had really old KO's (old style)and the last guy had new KM's.I gotta say, this is driver error.
Not a reason to judge the tire when others with the same tire survived.
Some guys can break anything.
I guess if you want to shell out another 125.00/tire every month under warranty.To each their own. I kinda like getting a bit more out of my tires before replacing.Sounds like a testimony to stick with BFG KOs !!
