Welcome to the Overland Bound, OB1 Beta Test Program
Please keep in mind this is
Beta Software. This means it may be broken in some cases. This is expected. There some "Known Issues". If you leave a post and it does not get a response it probably means the post goes into the "Known Issue" category, and we appreciate your report.
Please provide any specific information about issues you find. You can do that right here in this thread.
Known Issues:
- No work has been done for tablets or landscape mode. It may work, but that's only by chance :)
- Map and Rally Point are not yet released
- You will see "Member Upgrade" even if you are a Member
When reporting bugs:
Provide report type: Bug, Feature, or Improvement.
Provide platform: iOS or Android
Provide Device Info: What are you using?
Reproduction steps: Let us know how to reproduce the issue.
Ideas: We want to know what is frustrating, unclear, or could be improved. Most importantly, what would make you use this app as your preferred forum, map, event app.
APPLE BUILD: OB1 iOS Build
ANDROID BUILD: May be downloaded here (option to install APKs must be enabled): Android Build:
OB1 Android Build
Thank you again, we appreciate the feedback!
- Michael and Team
Bug OMC-649 Profile buttons go to blank white screen 15-May-20
Bug OMC-621 Profile Post Message should refresh when posted 15-May-20
Bug OMC-597 User profiles in Messages should display user groups. 15-May-20
Bug OMC-619 Draggable Map Pin in "Add Location" screen still jittery 15-May-20
Bug OMC-632 Unable to tap on someone's username in "tag list". 15-May-20
Bug OMC-596 Notification “[username] wrote a message on your profile” does not link to Status update (profile post) in the Status update page. 15-May-20
Bug OMC-535 Dark Mode in Production 5-May-20
Bug OMC-623 Cannot continually scroll in the Forum Feed 5-May-20
Bug OMC-111 Forum Post Cards show thread creation date, not latest activity date 5-May-20
Bug OMC-386 App Crash 5-May-20
Bug OMC-117 Post Image Previews set to low resolution 5-May-20
Bug OMC-171 "Watch" and "Read Later" icons are the wrong color. 5-May-20
Bug OMC-170 Single post "online indicator" is not showing. 5-May-20
Bug OMC-172 Single Post card does not display the time of post creation. 5-May-20
Epic OMC-11 MVP Forums: 10a_OB1_Forum_MemberProfile_V1 14-May-20
Story OMC-633 Authenticate through new API Endpoint 15-May-20
Story OMC-247 Member Map Member Detail Popup 15-May-20
Story OMC-188 Expanded Rally Point Location Tab 14-May-20
Story OMC-195 Rally Point RSVPs 14-May-20
Story OMC-624 Under Home Screen in "My Community" Remove "Load More" 5-May-20
Story OMC-439 Settings: Enable Dark Mode 5-May-20
Story OMC-232 Fully Implement Light and Dark Mode Toggle In App 5-May-20
Story OMC-194 Create Rally Point Map Invite 5-May-20
Story OMC-543 Create POI API 5-May-20
Story OMC-612 Implement Follow User API 5-May-20
Story OMC-122 Render basic user info in post header 5-May-20
Story OMC-121 Render featured image (first image) of every post 5-May-20
Story OMC-124 Allow user to add threads to Watch list (XF) 5-May-20
Story OMC-123 Render Post meta (time & post count) 5-May-20
Story OMC-126 Filter content using pills 5-May-20
Story OMC-125 Allow user to add threads to Read Later list (local client) 5-May-20
Story OMC-235 Implement, "You've Seen it All" Interrupt in Forum Feed 5-May-20
Story OMC-120 Render single post card 5-May-20
Sub-task OMC-575 OMC-187 Implement reusable Mapbox Location Picker 15-May-20
Sub-task OMC-338 OMC-158 notification icons for notification types. 13-May-20
Sub-task OMC-578 OMC-187 Identify and Implement an alternative UI for custom number of rigs 13-May-20
Sub-task OMC-574 OMC-187 Build View Invites Modal 13-May-20
Sub-task OMC-573 OMC-187 Implement Create Form Validation 13-May-20
Sub-task OMC-576 OMC-187 Build Invite Members from Map Modal 13-May-20
Task OMC-631 Create Badge Detail screens 15-May-20
Task OMC-456 Evaluate and select cross-platform error logging solution 5-May-20
Task OMC-606 Remap bundle ids to match the existing OB Talk app 5-May-20
Task OMC-607 Integrate Firebase analytics into mobile app. 5-May-20
