Axes
FJOmega
Whittier, CA
I have this 28" Fiskars Chopping Axe (not a spliter).. It's been mounted to the roof rack but hasn't really affected the blade. I've used it for chopping up a tree blocking the trail on one of the adopt a trail clean up days, it seemed to cut pretty well. Since then I've just used it to split some firewood.
RaggedViking
Readsboro, VT
Reactions: tom
mtbkr
This is a good thread.
Is there an advantage on what kind of material is used for the handle? Between wood, fiber glass or other material, which is a good option for something that stays out on the roof rack and exposed to elements all the time?
Wawa Skittletits
Local Expert East Region USA
Expedition Master I
5,079
Wilkes-Barre, PA, USA
Drew
Hawley
WRBZ674
USN veteran
I keep a Nupla pulaski axe with a molded in fiberglass handle right next to my fiberglass handled #murderspork on the rack specifically for that reason mtbkr. They're not up there year round but I like to not even have to think about it.
Reactions: mtbkr
KellyS
Anderson, SC
Kelly
Slatton
I'm looking for a good reliable axe that won't break the bank. Gerber, Fiskars or something else?
Masheen365
South GA
My opinion: the best axe is the one you have. I bought a fiber handled axe from Tractor Supply for around $15 and have been using it as much as I need. Spent the last two days off chopping up roots around a busted water line in the yard. It's been good, I put an edge on it with an angle grinder and touch it up with a bastard file whenever it needs it.
KellyS
Anderson, SC
Kelly
Slatton
Thanks Steve! I came across that thread a few days ago but couldn't find it again.
1largemouth
Martinez
In my opinion spend a little extra o a good axe and get quality. Gransfors are not cheap but will last!
Kelly
Kelly
Herrin
KFØDEX
I carry a chain saw, so I really only use an axe for splitting. I picked up one of these for < $40. It chops better than a maul, but splits better than an axe.
Besides, everyone knows, the best axe is the one that matches your shovel, Hi-Lift, and gas can ;-)
Bob Seaborn
barnsley , south yorkshire ,united kingdom
Bob
Seaborn
Joey D
Holladay, UT
I have an Estwing Sportsmen Axe. I prefer to have tools that I'm going to rely on not be made in China since in my experience I've had a greater fail rate with those (tools I don't rely on heavily come from Harbor Freight). But the Estwing is small and can fit behind my rear seats. One of these day I might upgrade to one of their long handle axes, but for what I've experience thus far the 14" one was fine.
Reactions: 1largemouth
