Anyone mounted a roam case to a roof rack/ crossbars?
Salvador_5a0cae
Savannah, GA, USA
Salvador
Andrade
Hi, I have a ROAM 83L on its way and I’m looking to mount it to my LFD crossbars, has anyone drilled into these cases to mount them? If so what worked best for you? What hardware did you use? I am aware that ROAM sells mounting hardware but is an additional $200 so that’s a no go.
Thank you.
Viking1204
Fort Walton Beach, FL
Viking
Air Force Veteran
I built my rack out of Superstruts and mounted a case I got from Harbor Freight similar to the ROAM cases. I drilled 4 holes in the bottom the case and ran bolt thru it anchoring it to the super struts. I used rubber washers to make sure it was water tight.
Reactions: KAIONE and grubworm
Salvador_5a0cae
Savannah, GA, USA
Salvador
Andrade
I believe this is the route I’m going to end up going, didn’t want to drill it but their mounts are an additional $200.
Reactions: Viking1204
Viking1204
Viking
Air Force Veteran
I figured holes in the bottom with rubber washers should keep water out pretty good since water doesn't generally work its way upwards!
Reactions: KAIONE
KAIONE
Vancouver, WA, USA
Kanak
Attack
I have a roof rack and drilled mine, used bolts etc. No silicone and rubber washers just plain washers and wing nuts on the inside and haven’t had a single drop of water get in. I take them on/off a lot. I live in the PNW and really don’t see how water would be getting in the bottom holes unless it was able to pool up somehow.
TK-421
East Aurora, NY, USA
Andrew
Wenner
Thank you.
Mount on lfd is easy, use the hardware they give you that has a bolt with hex, and the nut that is a rectangle shape. Measure and drill holes in case, put bolt in down through drilled holes, then from undeneath the case, a rubber washer, then the rectangle nut..dont tighten. Then position the nuts to fall into slots of the crossbars. From underneath, turn rectangled nuts perpendicular to the slot...tighten with hex from above...done. hope that makes senses.... make sure to use a big washer and the lock washers lfd provides as well...
