I have been getting familiar with the MXT275 I installed in my JK yesterday. It seems to be a very competent radio. We have not "range checked" it yet with Motorola T600s but for sure the communications are clear and carry no static artifacts as the TC button is released. One area that needs some clean up is the way Midland and Motorola chose to number the "unique" codes, these are commonly refereed to as "privacy codes" but they are really "ignore codes" . Anyway there seems to be two types; analog and digital. The first 38 code numbers are the same for both the Motorola and the Midland these are the 38 analog tones. Motorola simply continued numbering the digital codes as; 39, 40, 41 ETC. Midland decided to start the digital codes in their own sequence, hence the first digital code is 1. Every code after 38 must be translated if used on these two radios. If I want to use the first digital code I will set my Motorola T600 to code 39 and my
Midland MXT275 to digital code 1. I really like the Motorola scheme the best because all I would have to remember is that the digital codes start at 39...
